<~----> Question about High Def - Hardware Canucks
Old January 15, 2012, 01:51 PM
Blu's Avatar
Blu Blu is offline
Default Question about High Def
I don't think my graphics card I got for my HTPC has a HDMI port, I think it's just DVI would that still be providing HDMI? I'll try and get the card info in a day or two, but I believe it said it pushed audio and video out the same cable, is that possible with DVI? If so can DVI produce true HD?...I really want true HD badly.
Old January 15, 2012, 02:00 PM
a35599's Avatar
You can get DVI to HDMI adapter, DVI to DVI on your TV will still push HD though as the resolution is not more then 1080p in most cases. I cannot recall if DVI pushes audio, I think HDMI only will?? You can go right from your sound card/audio to your set though no problem.
Old January 15, 2012, 02:05 PM
difference between dvi and hdmi is hdmi carries audio. some dvi can as well but either will give you same picture quality/size
Old January 15, 2012, 02:06 PM
Lpfan4ever's Avatar
I know the DVI-HDMI adapter I had with my 4870x2 could pass through audio. However, I think they're pretty special adapters, although that adapter worked with my GTX570 for sound as well. Also, it'll handle 1080p no problem.
Originally Posted by encorp
Code:
<firebane> slightly used
Old January 15, 2012, 02:12 PM
Blu's Avatar
Blu Blu is offline
It's ok I got a 5670 and it does say HDMI on the box :)
Old January 16, 2012, 04:26 AM
Arinoth's Avatar
The 5670 can handle 1080p HD playback with no issues whatsoever, seeing as I've used one to do just that.
High vs Mid/low end SSD psyside Storage 7 November 19, 2010 12:56 AM
1st post: new i7 high end PC, overlocking question? drenerk New Builds 3 November 1, 2009 01:05 PM
[FS] BNIB High End Radiator 240 TFC **High Performance** qaz393 Buy/Sell & Trade 4 August 17, 2009 01:47 PM
High End Audio PC Merlin Audio 0 April 10, 2008 02:55 PM
How high is to high? James_8970 Overclocking, Tweaking and Benchmarking 5 January 8, 2008 02:00 PM
