Old January 10, 2012, 10:59 PM
Default 8800GTX -> 6870 upgrade for BF3 - disappointed in MP performance boost
Just installed my new 6870 today & tested it out in BF3 and so far am a little disappointed.
Other relevant specs (guess I should update my profile over on the right now):
X2 550 dual core @ 3.0
4gb RAM
1440 x 900 resolution
With the 8800gtx I was getting anywhere from 15-30 FPS on all low settings (in MP)
Never took a fps reading in SP.
I can load up the campaign & set everything to ultra, minus some of the AA & HBAO options and I get 30-60 fps.
Happy with that I dropped into MP and was getting 15-20 fps.
Turned everything down to medium & no AA / HBAO but only averaged around 30-40 fps.
My understanding was that BF3 was heavily GPU bound, but is my CPU really holding me up that much?
It & the old 8800gtx played BC2 on max flawlessly.
Seems strange that SP runs great on nearly max settings but that I have to turn it down so much for MP.
Any thoughts appreciated.
Old January 10, 2012, 11:14 PM
bc2 != bf3
They are two completely separate beasts
Old January 10, 2012, 11:19 PM
supaflyx3's Avatar
You are being majorly bottlenecked by your CPU, and multiplayer has A LOT more going on compared to campaign, a lot more explosions and more to render so it's more then likely that you'll get half the fps.
Old January 11, 2012, 05:01 AM
Bond007's Avatar
If your problem is only in multiplayer then your problem is not the graphics card. It would either be processor or Ram (more likely processor). I run BF3 on a similar setup (x3 710 with a gtx 460 and 4gb ram) and haven't noticed too much in the way of problems for multiplayer, but I believe I have the more processor heavy settings turned down (haven't had much time to play yet...I will update if I get a chance to play later today). Check your ram, cpu and gpu usage...run the game for a few minutes then minimize and check it out (whatever is at 100% usage is you bottleneck). I haven't had a problem with my 4gb ram, but I remember reading in the BF3 thread that others were.
Old January 11, 2012, 06:21 AM
Arinoth's Avatar
BF3 is rather CPU intensive, especially in multiplayer, as well seems to like to eat up/use a lot of ram. I found when I was playing the game on 4GB that I would eventually run into some stutter as it was running out.
Here I am: here I remain
Old January 11, 2012, 07:33 AM
Thanks for the input all. Guess it's time to go get an aftermarket cooler & unlock & overclock the CPU.
Old January 11, 2012, 07:43 AM
Yeah the x2 isn't cutting it anymore no matter what GPU you are using. My friend is having a similar problem but with a 6950. No matter what settings he tweaks it to, there is still some stuttering as the cpu is flat lining @ 100% util for long periods of time.
Old January 11, 2012, 10:09 AM
Omerta's Avatar
Do you still have your GTX by chance?
I'm looking for a card I can mod to a quadro
Old January 11, 2012, 12:26 PM
Bond007's Avatar
Just an add on to my previous post. My x3 710 is the bottleneck for me with multiplayer with a gtx 460. Had a chance to do a quick test online with 63 players. I never played around with the graphics settings or checked fps or anything yet, but my 460 was sitting around 60% utilization, 3.6gb of my 4gb ram used, and processor bouncing between 90-100%...all 3 cores being used. So your probably sitting in a similar boat only minus a core and add some mhz.
Old January 11, 2012, 12:35 PM
Sure do.
I'm at the opposite end of the country from you though (AB)
If you're still interested though I'm sure we can figure something out.
Ordered a CM 212 for my cpu so I'll unlock it to a quad (tested & it does work with my chip - just didn't want to on stock cooling) & see how much on an OC I can give it - hopefully that'll help a bit.
Help re: performance boost for i5 750 build charlie_watts New Builds 1 August 15, 2010 06:11 PM
EVGA GTX 460 Free Performance Boost shayan288 Video Cards 6 August 10, 2010 01:37 PM
what give me the best performance boost ? bc_tileguy Off Topic 6 March 23, 2010 05:21 AM
Will enabling AHCI boost performance? Matt Storage 17 February 20, 2010 07:22 PM
Performance Boost? WhiteAngel CPU's and Motherboards 16 December 27, 2009 03:58 PM
