  #21 (permalink)
Old January 16, 2012, 09:59 AM
OK got an update on this, and it's not good.
I'm now getting artifacts - both while gaming and just web browsing.
Is that a video card issue or could it be related to the unlocking into a quad?
I went back to stock speeds (even slightly under stock) and I'm still getting them.
I guess I can always revert to the dual core & see if I still get them.
Some of the reviews of the 6870 I purchased did complain about artifacts after a few days so I'm wondering if maybe it is the video card.
Thoughts?
  #22 (permalink)
Old January 16, 2012, 10:12 AM
techman95's Avatar
probably the video card its just a thing you have to deal with every now and then just return/rma it and be done with it you just get something bad now and then nothing to go ballistic about and swear of the brand
Amd....definitely a blond female.....not much on the cpu side, but always strutting about showing off her gpus
  #23 (permalink)
Old January 16, 2012, 10:24 AM
I followed bf3 for a very long time and watched as many of the DEV interviews as I could. One thing a lot of people don't know is a dual core CPU simply isn't enough. Bf3 will dedicate one of the cores JUST for audio and if I remember correctly it will use an aditional 2 cores for the game. You need to get a faster hampster. Also I noticed the 6870 onsale for 150 bux at memx.
Mah Rig now
Mah Rig before
My stuff for sale.
  #24 (permalink)
Old January 16, 2012, 10:47 AM
Shadowmeph's Avatar
Well if that is the case then people should only have to turn down off some of the audio features. Myself I usually turn down the music to almost 0 and the effects up to around 3/4 if there is voice then I turn that up to 7/8ths main stays 3/4
  #25 (permalink)
Old January 16, 2012, 12:50 PM
yycraven's Avatar
Thoughts?
Are the drivers all up to date on the card, you have your old 8800 maybe put that back in to see if you get same issues. mind you you will need to uninstall all the 6870 drivers and then install nvidia drivers .
  #26 (permalink)
Old January 16, 2012, 01:38 PM
Bond007's Avatar
Artifacts are usually GPU itself or drivers for it IMO.
  #27 (permalink)
Old January 16, 2012, 02:19 PM
Yep, drivers are up to date (11.12 I believe)
I'll roll it back to the dual core since that's faster than switching out video cards & messing with driver installs again.
Safe to say that if I still get artifacts it's the vid card then?
  #28 (permalink)
Old January 16, 2012, 02:36 PM
Soultribunal's Avatar
If temps are in check and you've rolled back the drivers and then tried up to date ones I would say its safe to assume the card. Though I have had issues like that in the past with Good cards, just crap ATI Drivers.
-ST
www.realhardwarereviews.com
  #29 (permalink)
Old January 16, 2012, 02:39 PM
Supergrover's Avatar
TBH I dont think it is the unlock I have never had a unlocked do this, hard locks yes, BSOD sometimes but artifacts is almost 100% GFX.
You could try the 12.1's they have been pretty stable for me..... other than the xfire profile builder/switcher
R.I.P.
  #30 (permalink)
Old January 16, 2012, 03:00 PM
Bond007's Avatar
I had random artifacts after installing my gtx 460 (was integrated hd 3200 before that) on my computer, but only while playing SCII (yes I got rid of all the old drivers before installing it). I tried so many drivers and thought it was the card, but it was all good after a fresh windows install and the latest drivers.
Help re: performance boost for i5 750 build charlie_watts New Builds 1 August 15, 2010 06:11 PM
EVGA GTX 460 Free Performance Boost shayan288 Video Cards 6 August 10, 2010 01:37 PM
what give me the best performance boost ? bc_tileguy Off Topic 6 March 23, 2010 05:21 AM
Will enabling AHCI boost performance? Matt Storage 17 February 20, 2010 07:22 PM
Performance Boost? WhiteAngel CPU's and Motherboards 16 December 27, 2009 03:58 PM
