Old March 12, 2008, 04:10 PM
Default Heat Issue
I'm having what I think are overheating issues with my graphics cards but can't figure out how to check them. I use two 7600gt cards at the moment that are only a year old and I have done no manual overclocking. As of late my computer has started to shut off randomly with no warning or slowdown before hand and I believe it is either my power supply or the cards.
Anyway, with my old XP drivers I could check the temperature of my cards, but with the new driver I can't figure out how to track it. Is there a way that I'm just missing? For that matter, could this problem even be caused by my graphics cards?
Old March 12, 2008, 04:19 PM
vertex112's Avatar
I would say that it is most likely the power supply for random system crashes like the ones you are experiencing. If you want to check temps use Speedfan:
SpeedFan - Access temperature sensor in your computer
otherwise you can download a tool off the nvidia website to monitor video card temps:
NVIDIA nTune
My Gaming Rig:
-Intel C2D e6750 @3.2ghz 1.35v 1600mhz FSB
-Asus P5K-P35 / e-sata / dual pci-e
-Patriot 2x1gb @ 1000mhz cas5
-Evga 8800GTS 320mb
-Antec Neo HE 500 modular PSU
-Coolermaster hyper6 hs/f
-x-fi xtreme music
-Acer 22" wide LCD 5ms
Old March 12, 2008, 04:44 PM
Many thanks, both should come very much in handy.
Old March 12, 2008, 07:03 PM
Riva Tuner is also a great utility to read the Graphics card temps and fan speeds.
Let us know what the temps are when you are get them going.
RivaTuner v2.08 download from Guru3D.com
RIG #1 - Intel E8400 // TRU-X 120 w noctua NF-P12 // GA-X38-DQ6 // GTX285 OC // 8g Ram OCZ Fatal1ty PC8500 // X-Fi Elite Pro sound // z-5500 speakers // OCZ 850w Gamer XTream PSU // WD Raptor 150g // Seagate 1Tb // 2xSeagate 500g ex// Logitec G-15 keyboard // Vista Ultimate 64bit
RIG #2 - AMD64 3500+ // Asus A8N-E // 8800GTS 512 OC // Enermax Liberty SLI 500W Modular PSU // WD Caviar 250g
Old March 13, 2008, 09:32 AM
It would seem not to be my graphics cards as the highest one of them goes is 55* under load.
Old March 13, 2008, 11:36 AM
sswilson's Avatar
Could still be the memory or VRMs on the vid card.
Are you overclocking your board at all? What have you got for a PSU?
What you're describing does sound heat related, but if you're overclocking the board it could be virtually anything.
Old March 13, 2008, 12:52 PM
Moneyless's Avatar
If his graphics cards are overheating his PC wouldn't just randomly shut-off like that. If it's the graphics cards you'd usually see deformation/discoloration/corruption of the image, then a restart. TBH I think it sounds more like a PSU or maybe RAM issue. A couple things you could do would be: make sure the cards are seated well, you never know (or the PCI-E connectors could be corroded, it's really rare but it could happen, happened to the AGP card in my mom's Dell...); you could also download memtest+ to check your RAM; and grab a cheap/borrow a multimeter to test the PSU rails (mainly 12V).
"I hate broccoli
And think it totally sucks
Why is it not meat?"
-Deadpool
Old March 14, 2008, 03:43 AM
OK I am going to suggest something that may sound "DUH" but will ask you to physically check anyway.
What sort of cooling is on your GPU? Stock? Is it the style that has the exhust port for the fan that exhausts out the rear slot of your case? If so is the metal tab removed from the back of the case in the second slot below the PCIe slot to allow venting?
I only ask because I have seen a case where a reputable computer store actually installed an X850XT which uses 2 slots, one for the card to plug in and the next one down to vent the cooler, with the tab still in place, there by creating back pressure on the cooler and not allowing the heated air to excape, causing GPU over temp conditions. See my story Case Cooling and Airflow - How much does it matter
Old March 14, 2008, 08:35 AM
Nothing is overclocked shy of the factory overclock that came on the cards. I'm thinking it is the PSU as it's just a 450watt that came with the case. Was planning on upgrading it in the near future but looks like that may be bumped ahead. I'll check the other ideas as well, thanks for all the help.
what is a decent air heat sink Shadowmeph Air Cooling 13 January 8, 2008 05:46 PM
Curious about buying heat pipes. chibi_man Water Cooling 2 December 12, 2007 10:00 PM
Modifying my CPU Heat Sink??? mattydies Water Cooling 8 June 25, 2007 09:03 PM
Heat sink and fan selection for Intel Pentium D 915... mattydies CPU's and Motherboards 6 March 17, 2007 09:36 PM
High heat does not damage HD's Babrbarossa Storage 8 March 8, 2007 11:20 AM
