Old January 4, 2012, 03:08 PM
Default Which Card (Screen Resolution)
My native screen resolution is 2048 x 1152 (Yes I know it's odd)
Should I even be considering a card with 1 gig of ram or should I be looking @ a minimum of 1.25 to 2 gigs of ram
Thanks for you input.
Old January 4, 2012, 05:12 PM
techman95's Avatar
well what games do you play? if you play games like bf3 or open world games then go with something with at least 1.25gb of vram preferably 2gb
Amd....definitely a blond female.....not much on the cpu side, but always strutting about showing off her gpus
Old January 4, 2012, 05:57 PM
Soultribunal's Avatar
Which Monitor runs at that Res?
Otherwise Opt for more VRam. Regardless of game.
-ST
www.realhardwarereviews.com
Old January 4, 2012, 08:29 PM
Dzzope's Avatar
Depends on games and settings you like to play with.. high AA (in most modern games) will probably make use of more than 1 GB whereas if your not bothered then you will probably just about get away with 1GB.
Have you a budget?
Your budget will limit your choices more than anything.
If i was gaming on that res I would probably want a 580 with 1.5GB or a 6970 with 2GB (but then I like to have plenty of shiny)
Old January 5, 2012, 04:10 AM
Thanks for you input guy's
CC was blowing out some 23" Samsungs a couple of years ago it's cheap but it works....
This is exactly what I thought.
Old January 5, 2012, 05:32 AM
Arinoth's Avatar
Yep, you're definitely going to want a card that has at least 1.5GB of VRAM in it, with 2GB being the most you'll really need (right now)
Here I am: here I remain
screen res controlled by actual screen or laptop supaflyx3 Mobile Computing 3 July 29, 2010 08:36 PM
Screen out of resolution when coming out of standby? chouchou Troubleshooting 2 July 28, 2009 04:53 PM
Blue Screen O death with New Graphics Card Reddog Troubleshooting 17 February 21, 2009 02:01 PM
1650X1080 max resolution, what card? Skyllz Video Cards 6 October 27, 2008 10:35 AM
