Old January 4, 2012, 12:09 AM
I haven't had any experiences with any of those cards but i'm thinking your best bet would be to go with the 560ti just based on performance
I'm also thinking that since they all use the same type of heatsink, they should pretty much sound the same at the same fan speed.
Old January 4, 2012, 12:35 AM
bissa's Avatar
ya, I would say the 560TI too. it might be the case, or that I'm more used to either noisy or quiet computers. sound is really a matter of opinion. but as was stated, of those they will all be about just as loud as the others, so go with performance.
plus, you can fold better with the NVIDIA cards. and of those the TI is better so might as well go with that :P
Old January 4, 2012, 01:31 AM
MonsterSound's Avatar
Default GTX 560 ti - 384 core vs. 448 core
Just a note that the MSI GTX 560 ti you pointed too is avail for PM at DC for $251.75.
Also, I was wondering if you had considered a GTX 560 ti version 448 core/320-bit/1280mb for ~ $283,
rather than the MSI 560 ti - 384 core/256-bit/1024mb version? Maybe outside your budget?
btw, the Gigabyte 448 core version is werrrry werrry quiet.
Code:
 my Heatware,  RFD &  eBay
MAIN: i5 3570 @ 4.5Ghz wH100 / Windforce 7970 / MSI Z77A-G45 / 8gb G.Skill 2133 1T / ASUS 25.5" / Antec P280 / PCP&C 950 / Intel 520 SSD 2400gb / Eclipse / G3-Lazer / YSM1 / z5300 / Win7 Pro64 / APC Xs1300
HTPC : nMedia6000B / AMD X2 4400+ / M2A-VM / Corsair 4GB 800 / LiteOn Blu-Ray / 8800GT / Samsung 46"LCD / 2x2TB / OCZ500 / ATI550 / Wrless Kbrd & Rmte / z-5500 / Win7Pro / APC700
"You must be the change you want to see in the world"
- Mahatma Gandhi
Old January 4, 2012, 06:37 AM
I was looking for the twin frozr cooler because i hear good things about it.
Monster Sound, yes my budget on graphics cards is not that big, i was hoping to spend somewhere below 250 and closer to the 200 dollars range.
I am also wondering if the difference is noticeable between the 560 and the 560 ti considering that the core clock and the memory clock is about the same.
Old January 4, 2012, 01:55 PM
The 560 ti, since it's new and the 6870 is not
Old January 4, 2012, 02:12 PM
The GTX 560 Ti will be the better performer as others have said, but it may not be the best choice based on your budget. Twin Frozr is quite good (based on what I hear), I was also looking at them when I was considering my own GTX 560 Ti. In the process of researching, I found that Twin Frozr (MSI), Windforce (Gigabyte) and Direct CU (Asus) were basicly competing against each other and providing similar advantages. Eventually I went for a Gigabyte GTX 560 Ti using Windforce and I must say I am not dissapointed.
All that to say you shouldn't limit yourself only to MSI, there are other very similar choices which might be cheaper. Finally, tell us a bit more about your budget, your rig(and your current GPU), the resolution you play at and the games you play.
You said you wished to stay below 250, is that shipped and taxed ?
Old January 4, 2012, 02:57 PM
Well, the reason I picked the twin frozr cause i was intrigued by it.
Since you asked Kilauea, this is for my first PC build that I am going to do. To clarify about the GPU budget, I am planning to spend a maximum of 250 before tax, and I'm planning to buy it from a local store so no shipping will be involved.
The resolution I had in mind was 1920 x 1080 for all my work/games.
Old January 4, 2012, 05:39 PM
I rather the GTX 560 ti.
Old January 4, 2012, 07:00 PM
Another vote for the 560 ti!
A quick question LacrosseTown Troubleshooting 5 June 13, 2010 03:44 AM
quick question twleung RAM 5 January 24, 2010 03:46 PM
Quick Question Shonoby Display Units 2 July 9, 2009 03:58 PM
quick question gingerbee O/S's, Drivers & General Software 6 May 19, 2009 05:12 AM
Quick Question /b/ derrXIII Video Cards 2 August 12, 2008 02:55 PM
