-   -   Blown Bad Caps (http://www.hardwarecanucks.com/forum/video-cards/50014-blown-bad-caps.html)
blitz January 2, 2012 11:28 PM
Blown Bad Caps
http://i42.tinypic.com/e2hhz.jpg
So this old eVGA Geforce 7300GS came out of my dads PC after he heard 2 pops on 2 separate occasions which he ignored. He thought it was something else since there was nothing wrong with his PC until one day the video just started shifting and that's when I found out it was this card.
I thought these were solid polymer caps but after some research, these are only the normal electrolytic caps without a sleeve and there are K vents at the top. Apparently these caps are from the Sacon FZ series which are low quality. I thought they look like solid caps but they are not.
Adzsask January 3, 2012 12:31 AM
Yes time to retire the old gal, or practice your soldering skills.:thumb:
Dzzope January 3, 2012 01:57 AM
Practice soldering. :D
TedShackley January 3, 2012 04:37 AM
yeah if you have an electronics supplier close by, just get a couple of replacements and hope the rest of it is fine
KaptCrunch January 3, 2012 05:39 AM
mite try
Lee's Electronic Components (2005) Ltd
4522 Main St, Vancouver, BC
may have what looking for
Chromey January 3, 2012 07:04 AM
Or I can sell you my Old LE :)
BrainEater January 3, 2012 10:41 AM
Replacing Capacitors is easy.
I try to use capacitors that are the same capacitance , with a higher voltage rating.Also make sure they are 105 c rated .
:thumb:
Eldonko January 3, 2012 10:43 AM
Easy to replace but not really worth the effort IMO. You can get a better card than that for probably $30
blitz January 8, 2012 08:01 PM
Thxs for the tips. My solder skills are okay but I might just keep to play around with.
jumpload January 10, 2012 04:04 AM
+1
agreed just replace the caps, its not that hard to do you know.
and do it fast and or remove the caps and keep em save so you know what to replace em with,when they start leaking what comes out is like acid and it can eat the traces on your pcb
