Originally Posted by Phill That is being rather melodramatic.
OP it is hard to give a good answer without knowing what res you play at. Generally 560Ti will hose a single 570. Now lets say you game at 25X14 etc (especially with AA turned up) you will have issues with the frame buffer on the 560Ti filling up. As is the case with AFR (alternate frame rendering) that SLI uses adding a second 560Ti for SLi does not give one twice the frame buffer (vram). Point is if you game at 19X12 or lower 560Ti SLI can be a great choice. However over 19X12 one may fill the frame buffer and cause a bottleneck. I run 25X14 and with 570 SLI I have to manage my in game setting in order to avoid running out of vram.
Hope that helped. |
You're right, but it's not really melodramatic, I actually had a EVGA GTX590 Classy for a bit and I RMA'ed/got reimbursed by NCIX (no $$$ loss) and got 2 X 560Ti's twin FrozrII/OC (and pocketed the $250 diff) and I get the exact same 3Dmarks11 Pscore (P8500)....but yes, at higher res than 1080P, 590 has the advantage....
If I had to buy today (instead of April last year) I'd go 2 X MSI 560Ti Twin Frozr III 448 cores
