Old January 8, 2012, 08:24 AM
Originally Posted by Eluder View Post
I'd be surprised as heck if you can't OC to 6970 speeds easily because my reference XFX 6950 has no problem surpassing stock 6970 speeds without any voltage increase.
Mind you I have aftermarket cooling, but so do you.
I meant to oc it like you would a proper 6970.
There were some limitations on them from what I recall of the different guides etc. higher quality chps or something.. can't remember the specifics..
I am sure if you look around for articles on unlocking and ocing the 6950 you'll find what you need
Old January 8, 2012, 10:29 AM
Well that's a given since the 6970 already starts off with a high GPU voltage, so it will likely OC higher than an unlocked 6950.
Even though that is the case, doesn't mean you won't get a solid OC out of a 6950. Mine did 975MHz with an increase in voltage, but I didn't feel it was worthwhile to keep the card at that speed since any game I ran played just fine at 900MHz with no voltage increase.
Old January 8, 2012, 10:48 AM
Birk's Avatar
The Diamond Radeon HD 6950 2gb I just bought in december unlocked without an issue :) It's got a super crappy tunnel type cooler on it that sounds like a jet engine but since i've got a full waterblock in the mail that doesn't matter anyways
If you plan to watercool and unlock check out the diamond
Sapphire Launches Radeon HD 6950 TOXIC Edition, Fastest HD 6950 Yet Sam_Reynolds Press Releases & Tech News 2 August 5, 2011 02:25 PM
radeon 6950 or gtx 560ti fatpc44 Video Cards 5 July 18, 2011 01:30 PM
XFX Radeon HD 6950 XXX 1GB or MSI GTX 560 TI ? Rush Video Cards 17 March 26, 2011 07:30 PM
Build Question for Radeon Options Surfer_2099 Video Cards 4 September 18, 2009 01:03 PM
