Old December 23, 2011, 09:51 AM
Sorry to tag on to, but I have a GTX 580, is it smart to take off the covering for better heat dissipation? or does it not really make a difference. It just take up a lot of space, and the help with the heat...
Old December 23, 2011, 10:44 AM
Nope, its actually preferable that you leave the covering on since in most instances its been strategically designed to redirect air flow over the heatsink and other components (although some shrouds are admittedly just there as a gimmick, but the adverse impact on performance will be minimal). Keep in mind that any physical damage to the shroud also has the potential to void your warranty.
Just thought I'd add, if you have anything that works similarly to the reference design (exhaust out of the back) it is REALLY important that you keep the shroud on since thats what directs the airflow, you're almost guaranteed to overheat without it.
Old December 23, 2011, 03:40 PM
Ps:on the topic of 3gb vs 1.5gb graphic card memory il kindly give you this link
GeForce GTX 580 3GB vs 1.5GB test, SLI and surround (page 1: GeForce GTX 580 3GB vs 1.5GB test, SLI and surround) - BeHardware
Questions about the GTX 460 vulcan500rider Video Cards 10 May 12, 2011 05:38 PM
Some questions BFighter Video Cards 6 March 4, 2011 04:18 PM
New SSD, few questions. aviduser Storage 14 June 16, 2010 04:45 PM
G25 Questions Cadence Peripherals 6 June 24, 2009 08:06 AM
Few questions AnthraxAdrian CPU's and Motherboards 2 April 13, 2008 07:08 PM
