Old December 16, 2011, 07:37 PM
Default 3way sli
which graphic card will perform best 3way sli
graphic card should be affordable
Old December 16, 2011, 08:02 PM
Jake_HT's Avatar
Spend your maximum budget on a 2 card sli setup for optimal scaling.
http://jakeht.deviantart.com/
Old December 16, 2011, 08:21 PM
neojjjk's Avatar
2 x Radeon HD 6850 in CrossFire
or 2 x gtx 570
http://www.tomshardware.com/reviews/...ce,3085-5.html
Old December 16, 2011, 09:22 PM
what means affordable for you?
Old December 17, 2011, 12:49 AM
GTX 560 ti 448 core, EVGA Classified but quantities are limited.
Old December 17, 2011, 04:11 AM
Seconded
Old December 17, 2011, 08:11 AM
yycraven's Avatar
What's your budget, might help others on what cards to choice from.
ASRock Extreme 3,2500K,NH-D14,Patriot G2 16GB ,WD 750GB,640GB Sata ,2 GTX 470 SLi Thermaltake toughpower XT850W,Tech Station. V243H,2253LW LCD
heatware
Old December 17, 2011, 09:23 AM
Adzsask's Avatar
Best and affordable for 3 way SLI would have to be EVGA 560Ti 448 core classified, they out perform 570's when you max the overclock.
evga x58 3way sli & true black rev. c issue dukelod Troubleshooting 2 May 28, 2010 05:00 PM
