Hello everyone. I was recommended to come here for some advice, hopefully I can find a solution for the problem.
I tried to install 286.62 drivers for my GTX 260 yesterday, but every time I run the installer it ends partway through the installation with the message: NVIDIA Installer failed
NVIDIA Update -Not Installed
PhysX System Software -Not Installed
3D Vision Controller Driver -Not Installed
HD Audio Driver -Not Installed
NVIDIA Control Panel -Failed
Graphics Driver -Failed
3D Vision Driver -Not Installed
I've looked over several forums and haven't had any luck with the fixes I've found.
Things I've tried :
Tried files downloaded from both nVidia and EVGA (the card's manufacturer)
Tried installing older versions of the driver...same result
Uninstalling old drivers, booting into safemode as Admin, using Driver Sweeper and attempting to install as Admin... Same Result
I started out with driver's from 10/10, but now the best version is from 2009 and it's what Windows 7 installs (and claims is the latest version). However I get error messages when I try to play any games.
I'm nearly to the point where I can't think of any other option than to format the HD and start over, but I really don't want it to come to that. I can't roll back teh driver now and for some reason System Restore doesn't even work.
I found a thread with a similar problem to mine, but no resolution.
Install Failure of Nvidia Drivers - Windows 7 Forums
For the heck of it I ran sfc /verifyonly and got "Windows Resource Protection did not find any integrity violations"
I'm stuck.
