Originally Posted by Bond007 550 Ti should be a very small upgrade over a 4850. If you are content with your current fps, then it would be a good replacement card, but if you want an upgrade (since you are replacing anyway) go to a 560/560Ti/HD 6950. |
What I worry about is if it will get rid of my flashing triangles during the game play. I cannot determine what caused it, but I was advised to upgrade my video card. So, if this 550Ti is not much better than 4850, maybe I should look for a better card?
HD 6950 is way over my budget, what about HD 6850?
http://www.ncix.com/products/?sku=63...X&promoid=1244
