Old December 1, 2011, 06:02 PM
Bond007's Avatar
Originally Posted by Chris View Post
Thanks. Just read SKYMTL's roundup for this card. It seems to be quite loud and hot. I will not like it when I am doing photo editing, altho I like the price.
Add $5 ($155 AR...but its more money up front) and have a quiet and cool running gigabyte version of the 6870.
NCIX.com - Buy Gigabyte Radeon HD 6870 Windforce 915MHZ 1GB 4.2GHZ GDDR5 2xDVI HDMI Display Port PCI-E Video Card - Gigabyte - GV-R687OC-1GD - in Canada
Old December 1, 2011, 06:27 PM
Yes, my HD4850 driver is the latest from AMD. I hooked up my computer to my Plasma TV using a DVI cable, and it has the same flashing geometric shapes. Would you agree that my HD4850 is a problem?
SKYMTL did not review this Gigabyte HD6870. I'll have to search for more reviews.
edit: 2 users in NCIX did say it is quiet and cool. I'll give it some thought. Thanks.
Old December 5, 2011, 10:13 AM
Default HD6870 or GTX560 Ti
I am now finally down to these 2 choices. 560 Ti is $50 more, but with a free Batman AC game which is about $40. So, which is a better card?
Old December 5, 2011, 11:04 AM
Shadowmeph's Avatar
Everyday I go through a simlilar thing as you . I am using an older 2gb 285gtx it is watercooled so there are no issues with the card but I have this dam upgrade bug I always wiegh the pros and cons of doing the upgrade and the one major thing that stops me every time is noise that is the one thing that I totally love about being watercooled is that it is quiet, I think that the only way I would upgrade was if I got a good deal on a newer card that either had the waterblock or the water block price was lower .
Old December 5, 2011, 11:20 AM
GT7R's Avatar
If you were going to buy this game by itself for 40$, then yes, get the card with it. The 560Ti is damn worth the extra 10$ you'll have to add.
What are your thoughts on this card? GIGABYTE GeForce GTX 460 1GB OC KRAFTIG Video Cards 15 October 7, 2010 12:07 AM
GIGABYTE Launches NVIDIA GeForce GT220 and GeForce 210 FiXT Press Releases & Tech News 0 October 12, 2009 11:10 AM
