Old November 28, 2011, 08:43 PM
Birk's Avatar
Thanks for the advice guys,
About the MSI Lightning, I've read that they sometimes develop a heat issue after a few months. Have you experienced this at all?
Old November 28, 2011, 10:04 PM
techman95's Avatar
on the twin frozer cooler thats highly unlikely they are close to the best air cooler there is right now. but for a single card go for the 6970 the extra ram will be a god send because i game at 1680x1050 and on newer games i run out of ram regularly on my 6870 so i cant run AA on my games now
Amd....definitely a blond female.....not much on the cpu side, but always strutting about showing off her gpus
Old November 29, 2011, 06:48 PM
NightRain's Avatar
I had a card that couldn't have been working correctly and I had to RMA it with the retailer. It was replaced quickly and I have had no problems at all. The card I had would get well into the 90's with a single card setup playing Battlefield 3 or Crysis 2. The replacement card would top out in the high 70's. I added a second one and the top one runs hotter than it use to but this is normal in crossfire and sli setups. There was about a 5-8C increase. Bottom card never goes past 75C though. This is under very high GPU usage. Most games keep the cards in the 60-70C range.
Lian Li PC-V1010B : Dell U3011 30" LCD : Dell U2311 23" LCD : Asus P6T Deluxe X58 : Intel i7 920 @ 3.5GHz : OCZ DDR3 12GB @ 1483MHz 8-8-8-24 : Noctua NH-U12P : 2x MSI 6970 Lightning CF : Auzentech X-Fi Forte 7.1 : 2x Samsung DVD-RW : Samsung DVD-ROM : OCZ Synapse 64GB Cache SSD : WD 1.5TB Black HDD : 2x WD 1TB Black HDDs : Corsair HX1000W : Cyborg R.A.T. 9 : Razer BW Ultimate Keyboard : Energy C-200 /w Yamaha RX-V667 AVR : Sennheiser HD555 Headphones : APC UPS XS 1200 : WIN 7 ULT 64
Old November 30, 2011, 06:53 PM
Birk's Avatar
I'm gunna grab 1 NCIX.com - Buy MSI Radeon HD 6970 Lightning 920MHZ 2GB 5.5GHZ GDDR5 2xDVI 2x Mini DisplayPort HDMI PCI-E Video Card - MSI/MicroStar - R6970 Lightning - in Canada for now and then in january i'll be able to afford a second one for xfire.
Thanks guys!
Old November 30, 2011, 08:31 PM
NightRain's Avatar
These cards have actually gone up in price. I bought one in early Oct for $380 and another one a couple weeks ago for $387 before $30MIR
Old November 30, 2011, 09:01 PM
Birk's Avatar
Sweet just got an email from NCIX the MSI 6970 lightning is now on for $369 :D
Old December 1, 2011, 11:54 PM
Birk's Avatar
Hmm, GTX 560ti 448 x1 for now and another later? or the MSI 6970 lightning x1 now and another later?
i hate choosing video cards when its been soo long since i had to do it.
Old December 2, 2011, 12:18 AM
Caldezar's Avatar
A single, better card is always the better way to go IMO. You avoid huge volumes of hassle with dual card drivers and game optimization. (Been down that road and I hate it.) I'd personally go with either the single 6970 just because you get the best value for your money with the larger buffer. But if you're gaming in 1080p, a 570 will do nicely as well. No matter how you slice it though, they'll both handle any game you throw at them in 1080p completely maxed out. Higher res means you'll likely think more about more memory though, so you're back to the 6970.
  #19 (permalink)
Old December 2, 2011, 12:41 AM
Birk's Avatar
so just a single MSI 6970 Lightning will do me for quite some time on its own? I don't mind not needing to dual card to get ultra settings if i don't have to
  #20 (permalink)
Old December 2, 2011, 01:13 AM
Supergrover's Avatar
Grab that lightning IMO over a 560ti, and yes I run 2x6970 DCII in xfire on a p67 and tight fit TBH if I was using a different case I Don't know about temps, mine load at 80+c considering when I had the single 6970 it was loading at 55-62c.
As Sam I had fan rattle from one of my dcii and a minor bend to the shroud fixed it fine.
That said I wish the lightnings would have been in stock when I purchased mine.
R.I.P.
Advice needed on a budget video card Synth Video Cards 15 September 4, 2010 05:29 PM
[WTB] Value/Budget 'gaming' video card PCI-E (9600GSO,3870HD,8800gt etc.) Koslov Buy/Sell & Trade 5 August 16, 2010 04:18 PM
Need a budget video card ParkerPWNT Video Cards 16 July 17, 2010 07:08 AM
Budget video card advice needed please. Mumbly Video Cards 9 January 17, 2008 05:59 AM
Budget Video Card Selection BALISTX Video Cards 14 June 17, 2007 09:24 AM
