Old November 25, 2011, 10:30 PM
The Quicken's Avatar
Default Little help?
I've got a Acer Aspire Compact PC x1900 that I use for torrenting and some other basic appications. I decided to upgrade it from 3gigs DDR3 to 8gigs DDR3 and I reapplied new thermal past to the Heatsync while I was at it. But I noticed on the MOBO this (see pics)
Seems to be a Dedicated Graphics card slot...which isn't a big deal but I would like if possible to run Duel Monitors off this PC, looking at the back I would seem to have some options but I'm not sure...thoughts/suggestions?
Old November 25, 2011, 10:43 PM
Soultribunal's Avatar
You can, you just need a low profile/low heat card in there. Something like a GT520?
ST
www.realhardwarereviews.com
Old November 25, 2011, 10:51 PM
ST
?? GT520? sweet!
Old November 25, 2011, 10:54 PM
Looking at the GT's I'm noticing that they seem large, (low profile)
I need/want dual VGA inputs or Dual DVI inputs.
Old November 25, 2011, 10:56 PM
I don't know of any low profile low power ones that have dual of each. Use a VGA to DVI' Adaptor perhaps? And if you think the 520 is too big, use a 430 instead.
ST
Old November 25, 2011, 11:21 PM
yycraven's Avatar
NCIX.com - Buy ASUS GeForce GT 520 Silent Fermi 810MHZ 1024MB 1.2GHZ DDR3 PCI-E VGA DVI HDMI Low Profile Video Card - ASUS - ENGT520 SILENT/DI/1GD3(LP) - in Canada
this is low profile
Old November 25, 2011, 11:46 PM
great, thanks for the help guys!
Old November 28, 2011, 07:41 AM
Since the 520 didn't fit go 430. The Heatsink should not be any thicker than the card's slot profile.
EVGA | Products 400 Series Family&sw=
ST
