Old November 24, 2011, 02:20 AM
Default What Graphics card should I get
Good day
I currently have the GTX570
I want to upgrade to the 580.
Which of the following cards should I get?
The GeForceŽ GTX 580 3GB (3072MB GDDR5) from Palit or the MATRIX GTX580 P/2DIS/1536MD5 from Asus?
How does the two compare with stock settings (without overclocking them)?
Thanks
Old November 24, 2011, 04:53 AM
Keltron 3030's Avatar
imho, there is no need for you to upgrade. You got a solid card that I am (and I'm sure others are) very envious of.
If you feel you need more performance from the card, then try overclocking. A GTX 570 can overclock to near-GTX 580 performance
Could you post links to the cards as well, specifically the one from Palit. Then we could possibly answer your question
FFFFFFFUUUUUUUUUUUU-
Old November 24, 2011, 11:28 AM
Thanks for the reply
I decided to go with the Palit which has 3GB of memory since I'm playing on a 27" screen. It's a bit cheaper as well
Old November 24, 2011, 01:01 PM
Did you take a look at this review regarding 3GB cards?
The Effect of GPU Memory on Surround & Stereo 3D Performance
Unless you run dual screen or 3D display you might actually find yourself losing FPS compared to the 1.5GB setups.
Old November 24, 2011, 01:28 PM
Dmitry's Avatar
HWC YouTube Reviewer
The only real Advantage i see of the 580, ONLY if you get the 3GB version. 570 could be OCed to 580 performance, so there is no point of upgrade...UNLESS! You have multiple monitors to run at high res so the full memory could be utilized, OR, you work with video editing apps like After Effects or Premiere, that can utilize GPU Acceleration and greatly improve your editing performance with more GPU RAM! Otherwise, save the half K and put it for some better use down the road!
Old November 24, 2011, 01:54 PM
Bond007's Avatar
I don't think that it will be money well spent. I would say don't bother swapping from the the 570. Just OC or add another 570.
Old November 24, 2011, 02:31 PM
If you want a 580 3gb why not just add another 570, it would definately outperform the single 580 hands down.
580 standard or 3gb, the difference was meant for multi-monitor super high res where the extra memory is used effectively, overclock that bad boy, worse comes to worse, you obviously have the coin to get a better card, so why not try and get the most you can out of it to begin with?
A 570 can handle anything out there even at 2560 reso on a single monitor, games like BF3 which are very taxing, play very well with the lesser cards, the 570 580 just allow higher res/more eye candy and higher minimum/average fps, the screen size doesnt matter its the settings/resolution you use.
I do not think it is $ well spent, if you want better wait a couple months for the 600 series to come out, then upgrade it, or go balls to the wall and get a 590 if you really want a uber card.
Old November 25, 2011, 06:21 PM
The performance difference between the GTX580 and the GTX570 is almost 15%, for the price difference of almost 100%. A GTX580 will not give you impressive results, unless you need the 3gb of vram.
Old November 26, 2011, 02:00 PM
Basically one of my PCs require a new card and the other one has a 8800GTS in it.
Currently my PC has the GTX 570, pc 2 8800GTS, pc 3 gfx broken
I want to put my GTX570 in pc 2 and put the 8800gts in pc 3
Therefore I want a New GPU.
Do you guys think that I should stick with the GTX570 and Upgrade pc 2 with something like a 560GTX?
How does one go about overclocking the 570GTX? I have no experience in overclocking at all, that's why I buy something new.
Old November 26, 2011, 02:15 PM
MSI afterburner = super easy to use, almost always works.
Yeah, unless you're a max settings only kind of nut, the 570 will play every game while looking amazing. A single 570 will have trouble with BF 3, metro 2033, AVP, Crysis 2 (dx 11 patch) maxed out.. but off the top of my head I can't think of any other games that will struggle. Still, you can play all games at pretty damn high settings.
The GTX 580 is a waste of money unless you're a hardcore gamer who demands the best and doesn't care about price (and has lots of disposable income). You can get the 560 Ti in a version with extra vram and go SLI for better performance/price. If you decide that you don't need max everything for your main, just upgrade your old computer to a new card :)
Alternatively, you could always see how the red team is doing these days with CF 6950s 2GB version.
Intel HD Graphics with Graphics Card MoUnit CPU's and Motherboards 4 August 6, 2011 03:54 PM
Which graphics card should I get? deltatux Video Cards 12 July 20, 2011 06:33 PM
AMD Extends Graphics Performance Lead, Launches World's Fastest Graphics Card? Again! FiXT Press Releases & Tech News 2 March 8, 2011 03:32 PM
graphics card? Generic User #2 HTPC Systems & Software 4 July 25, 2009 07:50 PM
