  #41 (permalink)
Old September 25, 2008, 06:55 PM
biff's Avatar
I use the enzotechs and the tape worked well for me too. IIRC in the instructions it says to apply pressure for 30s. Anyone find any r-theta numbers for the sekisui stuff?
i7 4790K @ 4.8GHz w/EK Supremacy Evo
MSI z97 Gaming 5
2x 8GB Gskill Sniper 2133 @ 2400MHz
EVGA GTX 280 (SC?)
OCZ Gamer Xtreme 600W PSU
Still rockin' the Cooler Master Cosmos on water
  #42 (permalink)
Old October 3, 2008, 11:47 AM
sswilson's Avatar
Just got my roll of tape in. Holy cwap that's a lot of thermal tape!!!! :)
I'm still working on my DFI Dark getting the enzo sinks installed, but the stock tape (pads) seem to work well if you are installing the whole block. They don't work so well when you cut the block up for smaller applications so this tape will come in handy.
I'm not sure, but I expect the tape will transfer heat better as it's normal tape thickness while the enzo blocks have pads.
  #43 (permalink)
Old October 3, 2008, 12:02 PM
3.0charlie's Avatar
Got mine too last evening, and will use it this week-end on the P5E and the second 280GTX.
Jeez... 50m. I'll never use all that.
Hydro-Quebec is salivating...
  #44 (permalink)
Old October 3, 2008, 12:06 PM
wish i seen this thread earlier i ordered some 3.5cmx3.5cm pieces at 0.54 each,lol
funny thing is i thought it was for attaching temp sensors to blocks/case.. doh,maybe i better just smoke cigs today and think/read,lol
Edit:can it be used for that? will it affect temp reading?
http://valid.canardpc.com/show_oc.php?id=932179
"Be so good at what you do that you cant be ignored"
  #45 (permalink)
Old October 3, 2008, 12:13 PM
Eldonko's Avatar
Hardware Canucks Reviewer
Ah nice, mine will prob get here today too then.
  #46 (permalink)
Old October 3, 2008, 12:17 PM
sswilson's Avatar
I don't see why it would be a problem. I'd remove the backing for the open side though as it might fall off inside your case and foul a fan.
  #47 (permalink)
Old October 3, 2008, 06:13 PM
biff's Avatar
Got mine wednesday, and yeah that's a crap load of tape! Quick 'n' painless, for sure I'll be using them again since they have some goodies that NCIX & DC doesn't. FWIW cheaper shipping for small items than DC even, though I had to wait a few extra days but I'm OK with that.
MSI z97 Gaming 5
EVGA GTX 280 (SC?)
  #48 (permalink)
Old January 15, 2010, 04:43 PM
0o0 0o0 is offline
Ancient bump (this was the first result with "thermal tape" on Google), does anyone have some tape in Toronto? Specifically scarborough. Retailers, fleabayers, etc. I just need a couple pieces to replace the ones on my 4870 because I got them dirty lol.
Would that arctic silver adhesive stuff work? Maybe mixed with mx-2 or as5?
  #49 (permalink)
Old January 15, 2010, 05:11 PM
never a good idea to mix that stuff.
"What is the colour when black is burnt ?" - Neil Young
  #50 (permalink)
biff's Avatar
Well I have about a ton of the stuff and I work at markam steeles area.... where are you?
MSI z97 Gaming 5
EVGA GTX 280 (SC?)
Thermal Paste??? Salavat23 Water Cooling 6 December 27, 2007 06:43 PM
Plumbers thread Tape Corpus Masochist Water Cooling 6 August 23, 2007 01:14 PM
How to properly apply thermal compound Corpus Masochist CPU's and Motherboards 9 August 11, 2007 08:12 AM
Does core2duo come w/ thermal paste Magice CPU's and Motherboards 4 July 12, 2007 03:40 PM
