Old March 3, 2008, 01:20 PM
lcdguy's Avatar
Default riva tuner
I have a question.
i have heard that the fan on the 3850's doesn't increase in speed as temps increase. If i can is there a way to use this to force the fans to run at full speed ? Sorry but i have never used riva tuner before. Also i am running a crossfire setup not sure if that affects it.
Help with ODIN's Power Tuner Malam Power Supplies 18 January 9, 2008 09:22 AM
Poor picture quality from TV tuner Sharkylegbreaker HTPC Systems & Software 7 November 29, 2007 02:03 AM
TV tuner/Capture card the_bandit87 Video Cards 2 November 14, 2007 11:16 AM
TV Tuner to rec digital feed Wiked HTPC Systems & Software 4 October 14, 2007 12:40 PM
Need a good TV Tuner for an HTPC Misoprostol HTPC Systems & Software 18 May 15, 2007 01:52 PM
