Old November 15, 2011, 09:54 PM
Default nvidia surround question
I have 2 1440 x 900 monitors and I wanted to know if i could set up surround if I buy a 1920 x 1080 monitor?
-the 1080p monitor is in the center
Old November 16, 2011, 05:53 AM
Arinoth's Avatar
You would need to have 2 graphics cards from nVidia to do this. You would also limited to the 1440 x 900 resolution on the 1920 x 1080 if memory serves correctly. What are your system specs?
Here I am: here I remain
Old November 16, 2011, 06:17 AM
SKYMTL's Avatar
HardwareCanuck Review Editor
It will not work properly as you need three monitors of the same native resolution.
Old November 16, 2011, 09:39 AM
Manufacturer Rep
I can tell you the Galaxy MDT cards can do it, but your max resolution will indeed be 1440x900 on all three displays (4320x900 total).
Old November 18, 2011, 11:54 PM
alright thanks, I know now that it is not worth it
Official ATI Eyefinity/nVidia Surround Discussion Thread SnoSalmon Display Units 245 March 3, 2014 09:32 PM
Question on surround/eyefinity Beastylemon Display Units 7 September 30, 2011 11:35 AM
Nvidia 2D 3D surround vision scruff Display Units 15 January 24, 2011 01:37 PM
nVidia Surround Resolution Oddity DkRk Video Cards 9 January 19, 2011 05:19 PM
