Old November 14, 2011, 09:54 AM
Default Does your GPU fan burn or brake something?!?!?
I was wondering about the radeon hd 6970 graphic card's fan would burn if you put it @ 100% speed for a long time?
I mean it has so many RPM... 5000+
( Sorry for bad english )
Old November 14, 2011, 10:00 AM
dandelioneater's Avatar
It should be fine. If their was some dirt or debris in there causing any rubbing it might be an issue, otherwise I wouldn't think so.
Old November 14, 2011, 10:18 AM
Arinoth's Avatar
Just hope its not the Asus CU II fans, otherwise those things will begin to rattle over time.
Here I am: here I remain
Old November 14, 2011, 11:11 AM
KaptCrunch's Avatar
fan @ running 100% on desktop?
re-apply thremal paste on heatsink, make sure that inside case is getting cool outside, not recycled heated air
Old November 14, 2011, 02:08 PM
no no, it's the XFX 6970 with 1 fan @ the right side
( The coolest GPU from the 6970's from my opinion tbh :P )
Old November 14, 2011, 02:13 PM
Soultribunal's Avatar
There is nothing wrong with running a FAN at 100%.
I ran my GX2's at 100% for 2 years of solid folding and they never failed.
They are designed to be run at any speed for a good length of time (Depending on the MTBF).
-ST
www.realhardwarereviews.com
Old November 14, 2011, 03:03 PM
martin_metal_88's Avatar
Those fan should be fine no problem at 100%. I second that Asus CUII are epic crap.
HD Plasma TV, Burn in or something else? dosmond Display Units 7 May 14, 2011 01:22 AM
Burn dvd-rip martin_metal_88 Guides & How-to's 9 September 22, 2009 05:37 AM
could i burn out my mobo by....? andynerd CPU's and Motherboards 9 December 28, 2008 10:29 PM
Burn time enzeo Storage 3 July 24, 2007 11:13 PM
CPU Burn-in time Bognostraglum Troubleshooting 7 April 28, 2007 08:25 AM
