Old November 13, 2011, 11:16 AM
Jim's Avatar
Jim Jim is offline
Default stupid idea ? here's the plan,thoughts
I have budget of $750 cnd (includes freight & tax) I,m using one 24 inch Samsung monitor ,motherboard has 1 16x pcie slot ,want to play BF3 @ 1080p no limits (don't need mmsa ?) so thinkin of ordering this Newegg.ca - MSI R6990-4PD4GD5 Radeon HD 6990 4GB 256-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card with Eyefinity dumb idea ? don't ever want to see frame rates suck( I'm aware of the possible noise issue )not a brand fanboy, open to alternatives
thanks guys
Old November 13, 2011, 12:40 PM
I think you'd be better off going with a 580 if it's just a single card setup, seeing as the 580 is the most powerful single gpu card.
Sadly... for BF3, you will need 2 580's to run everything at max 1080p. Kinda sad how you gotta pump 1000 dollars into gpu's if you wanna run to the fullest.
Old November 13, 2011, 12:47 PM
Jim's Avatar
Jim Jim is offline
sad,yep,that's why i played on consoles for the last couple a years but not for bf3,thanks man
Old November 13, 2011, 12:52 PM
A 6990 will perform better than two GTX 580s in BF3. Crossfire has a near 100% scaling in bf3. Even at high settings all ati cards appear to beat out higher end nvidia cards.
At ultra settings it comes down a little since ati has to tackle msaa. But a single 6970 can handle the game on ultra at 1920x1080. It's cutting it close, so a 6990 will definitely do it. But a 6990 is more for high resolutions.
Old November 13, 2011, 01:00 PM
rjbarker's Avatar
Post some numbers please, everything I've seen puts a 6990 pretty much at par with 590....we all know 2 x 580's SLi will out do a single 590, OC the 580's and its "no contest".
You certainly wont need 4GB of VRAM for 1080...a single 580 would be fine, just turn off MSAA, leave AF x16.
Firestrike Extreme: 21.452
MARK 11: 32.530
Old November 13, 2011, 01:07 PM
Jim's Avatar
Jim Jim is offline
are you saying the 6970 is cutting it close ? also wouldn't the 6990 ensure frames/sec never dropping below 60 ?
interesting,that'd leave room for a sli mother board
Old November 13, 2011, 01:14 PM
yycraven's Avatar
Are you telling me that this card here would not give you over 60FPS all the time playing BF3 6970 2GB
Newegg.ca - XFX HD-697A-CNFC Radeon HD 6970 2GB 256-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card with Eyefinity
Old November 13, 2011, 01:18 PM
Jim's Avatar
Jim Jim is offline
who me ? nope,not tellin anything,don't know enough on the subject,that'd be great if a 6970 would stay above 60 all the time
Old November 13, 2011, 01:19 PM
rjbarker's Avatar
^^^ 1080 is not a killer demanding res guys..any single high end GPU should be able to handle BF3 fine by simply turning MSAA down from x4 to x2.
1920 x 1200, 2560x1440/1600 is going to require some more "poop" ;)
MARK 11: 32.530
Old November 13, 2011, 01:23 PM
A single 6970 will run the game on ultra settings. If you want, a 6990 will get higher fps.
An extra amount is the 6970 will get 44 while the 6990 will get 80 fps.
http://www.tomshardware.com/reviews/...e,3063-12.html
Mind you I'm talking about 1080p. Even a single gtx 580 will run the game. 1080p isn't a high res, it's basically standard these days and doesn't require the best solution to max out games.
http://www.tomshardware.com/reviews/...ce,3063-3.html
http://www.tomshardware.com/reviews/...ce,3063-8.html
BF3 runs better on any ATI card. A gtx 580 is not better than a 6970 in this game.
OC the 6970s and it's no contest. Don't go oc for oc, go stock for stock and ati wins this round. Gtx 580 is better overall, but for BF3, ati got the benefit.
Stimulus Plan Eldonko Off Topic 40 January 29, 2009 12:15 AM
Here is the Plan Soultribunal Water Cooling 53 December 12, 2008 01:44 PM
plan to get another router CTA Networking 10 November 5, 2008 04:05 PM
Trying to plan a WC build Iamcanadian7 Water Cooling 1 September 9, 2008 08:24 PM
BF : BC Anyone here plan to get it ebdoradz Gaming 8 June 12, 2008 08:55 PM
