Old November 12, 2011, 04:50 AM
Liu Kang's Avatar
Default Concerns around the 590...
Read a lot about issues with the GTX 590s... I'm at the point where I need vid cards for my monster build, but I only have 2 slots avaiable.
My question is simple, are the issues around the 590 simply driver based and resolved, or should I stick to a couple of 580s in SLI and be happy (with some extra money in my pocket).
I ask because I'm reading lots of conflicting reports...
TIA
LK
WORK KANG: Silverstone SG03 | EVGA x58 Micro w/ 920 @ 4.2Ghz | Sapphire 5970 | 12GB Dominator DDR3-2000 | 240GB Revodrive X2 | SilverStone ST650F
MINI KANG: BitFenix Prodigy | Asus P8Z77i Deluxe mITX w/ 2600K @ 4.5Ghz | EVGA GTX 680 2GB | 8GB Vengeance DDR3-1866 | 2x Intel 160GB SSD | Corsair AX650
KANGZILLA: Custom MM Ascension | SR-2 | 2x X5650 | 2x SilverStone ST1000F | 2x Intel 160GB SSD | 15x 120mm rads | Under construction...
Old November 12, 2011, 10:56 AM
JD JD is offline
Dual GTX580's are faster anyhow...
Unless you're buying the ASUS RoG GTX590 which actually uses full-blown GTX580 cores.
Old November 12, 2011, 01:25 PM
OmegaRED's Avatar
590 is memory starved and held back so overclocking won't get you anywhere, makes more sense to go SLI 580's and laugh your ass off as it overpowers just about everything.
E-Penis Specs:
Coolermaster Cosmos II \\ Intel i5 2500K@4.8ghz \\ Gigabyte PA67 UD7\\ MSI Twin Frozr GTX 680 SLI \\Corsair Vengeance 8GB LP \\ Seasonic Platinum 1000W \\ X-Fi Titanium HD \\ OCZ Vertez 3 120GB \\ RAID 0 Seagate Barracuda 1TB SATA6G 64MB \\ Samsung 27" 3D LED Monitor \\ Logitech G5 \\ Logitech G-15 Keyboard \\ Logitech Z-5500 \\ Sennheiser 595 \\ Windows 7 x64
Old November 12, 2011, 03:22 PM
GT7R's Avatar
It is not memory bottlenecked at all, I would say a 580 is closer to be memory choked, because the 590 is essentially a two under clocked 580s in SLI... So the higher clocked separate 580's will be more bottlenecked my their RAM.
On the OP's question - no, there aren't any specific issues with the 590, apart from it being not a good OCer (actually as almost any other dual GPU).
Performance wise is within a few percent the same as dual 570s, a bit better at higher resolutions.
Old November 12, 2011, 04:32 PM
Soultribunal's Avatar
There should be no driver issues with the 590, as it is the same as two 580SLI. However finding one new is impossible these days.
I would get a pair of SC 570's and be done with it.
ST
www.realhardwarereviews.com
Old November 12, 2011, 05:15 PM
The EVGA Classified 590 is in stock right now and comes with some super sweet goodies. I just watched the newegg unboxing video last night. :)
Newegg.ca - EVGA 03G-P3-1596-AR GeForce GTX 590 (Fermi) Classified 3072MB 768-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
2 other 590's are in stock as well as I type this reply.
Old November 12, 2011, 05:18 PM
rjbarker's Avatar
Liu....for that Monster build I wouldn't go near the 590's, either a pair of EVGA 580 3 GB or a pair of EVGA 580 Classy, also 3 GB ;) I thought that was an SR2 board...?....how come only 2x PCI-E ?
Firestrike Extreme: 21.452
MARK 11: 32.530
Old November 12, 2011, 05:27 PM
Liu Kang's Avatar
Thanks for the input, gents.
I plan to use the other slots for other hardware... Tri-SLI is also an option, depends if I can get the LSI card to work properly.
LK
Old November 12, 2011, 06:52 PM
rjbarker's Avatar
I see, I was running Tri Sli 580's for a few months as well, crazy speeds with FPS / Benches, only for high Res set-ups, definitely the 580 3GB would be far better than 590's IMO ! ;)
MARK 11: 32.530
Old November 12, 2011, 07:06 PM
Liu Kang's Avatar
2560x1600 or bust ;)
LK
Concerns with GD235HZbid and Alternatives jyuphoria Display Units 5 October 20, 2011 08:48 AM
Swiftech hd 5870 concerns aviduser Water Cooling 1 May 14, 2010 12:17 AM
Gaming Rig concerns and questions [i7/x58GT] Godinster New Builds 3 November 28, 2009 09:45 AM
eVGA 750i FTW Video concerns Rommel Troubleshooting 4 July 15, 2008 07:03 AM
2900XT pic series, and WC concerns Babrbarossa Video Cards 1 May 10, 2007 09:45 AM
