Old November 12, 2011, 06:21 PM
rjbarker's Avatar
^^^^ Then its a no-brainer...GTX 580's 3GB all the way....will be far better than 590's at 1.5GB;) Even my set-up with 2560x1440 would be better with 3GB Cards....in fact I'm entertaining selling off my present Cards (while prices are still solid) and picking up a couple of 3GB versions... :)
Newegg.ca - EVGA 03G-P3-1588-AR GeForce GTX 580 (Fermi) Classified 3072MB 384-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
or
Newegg.ca - EVGA 03G-P3-1584-AR GeForce GTX 580 (Fermi) 3072MB 384-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
For what its worth the biggest complaint I was hearing re:590's was/is low Clock speeds, inability to OC without instability and the "Micro-stutter issues" that seemed to have plagued nv dual GPU Cards.
Classified Ultra SLi "Procyon"
http://i30.photobucket.com/albums/c3...2/DSC02888.jpg
http://i30.photobucket.com/albums/c3...2/DSC02889.jpg
Evga 4.2 Ghz Club....
Old November 12, 2011, 08:03 PM
Ummm a single 590 at high reso and with settings thrown up, starts couging some, most benchmark places show that yes it is in fact somewhat memory starved(dont forget 1.5gb per chip loses some to overhead so in effect is maybe 1.2gb memory or so) overclocking the memory some helps in this regard. This has also been shown with ASUS MARS II quad sli and even somewhat with Single Mars II, it starts to cough where some of the cards that have enough Vram wouldnt.
2x560ti overclocked, 2x570 or 2x580 will be faster and sometimes with the right shopping cheaper, sometimes alot, then a single 590(in the case of the 560Ti or 570) I myself would rather have 2 properly designed cards that use properly rated coolers, Vregs and such, then 1 expensive, barely able to handle its self, usually unable to overclock because of Vregs already stressed card.
If oyu have the $, 2 3gb 580 will absolutely decimate everything in thier path, 2 560Ti superclocked/OC/Classified/FTW you get the picture will also be bleeding fast and be alot less $ then 2x580 3gb.
I think, only 2x580 3gb will be able to play comfortably with most things maxed at 2500+ range reso without suffering, dont but into the hype and waste your $ and be upset, its not worth it.
Oh yeh, and better make sure you have a very good power supply in the 850+ range.
Old November 16, 2011, 09:30 AM
Liu Kang's Avatar
Went with the 2x GTX580s (3GB)... can't wait to get this damn rig completed and under water!
2x 1000 watts ;)
LK
WORK KANG: Silverstone SG03 | EVGA x58 Micro w/ 920 @ 4.2Ghz | Sapphire 5970 | 12GB Dominator DDR3-2000 | 240GB Revodrive X2 | SilverStone ST650F
MINI KANG: BitFenix Prodigy | Asus P8Z77i Deluxe mITX w/ 2600K @ 4.5Ghz | EVGA GTX 680 2GB | 8GB Vengeance DDR3-1866 | 2x Intel 160GB SSD | Corsair AX650
KANGZILLA: Custom MM Ascension | SR-2 | 2x X5650 | 2x SilverStone ST1000F | 2x Intel 160GB SSD | 15x 120mm rads | Under construction...
Old November 16, 2011, 09:56 AM
rjbarker's Avatar
^^ Nice Liu...Evga?....if so did you go with the Vanillas or Classy?
Concerns with GD235HZbid and Alternatives jyuphoria Display Units 5 October 20, 2011 08:48 AM
Swiftech hd 5870 concerns aviduser Water Cooling 1 May 14, 2010 12:17 AM
Gaming Rig concerns and questions [i7/x58GT] Godinster New Builds 3 November 28, 2009 08:45 AM
eVGA 750i FTW Video concerns Rommel Troubleshooting 4 July 15, 2008 07:03 AM
2900XT pic series, and WC concerns Babrbarossa Video Cards 1 May 10, 2007 09:45 AM
