Old November 12, 2011, 05:15 PM
Originally Posted by Ed103194 View Post
I get low 30s-70 fps on ultra 1920x1080, on a single GTX570, and to my understanding two 560ti's should be more powerful than a single gtx570
You probably don't have MSAA on because a single 570 even overclocked to hell can't push those numbers.
Old November 12, 2011, 06:54 PM
Coach's Avatar
Sli 580's here n no issues at all with newest WHQL ...all Ultra with 2x MSAA and solid 75-100 FPS @ 2560x1440, knock about 10 FPS off with 4xMSAA.....the game looks amazing!!!
May I ask how full your frame buffer is at your settings? I run at 2560X1440 with my 570 SLI and I find that I am maxxing my vram usage. I am very curious to hear back from you!
Old November 12, 2011, 07:31 PM
rjbarker's Avatar
Phil....
.Max here too (1.5GB)...no surprise as many of these games suffer what Skymtl explained as Memory Leaks...(too geeky for me to get into), but in a nutshell some of these games will utilize as much VRAM as you can throw at em...whether it be 1GB, 1.5GB or 3GB.....on my set-up 4xMSAA things dont feel quite as "fluid" as I like, much better with 2xMSAA with no significant loss in PQ.
I also found running the Cards at 875 / 2100 is a little better than 835/2050....just have to keep my fans manually set at 78% ;)
With my settings above Min FPS have never dipped below approx. 60 FPS in heavy battle scenes
Firestrike Extreme: 21.452
MARK 11: 32.530
Old November 12, 2011, 08:28 PM
Coach's Avatar
Thanks for the reply.
Old November 12, 2011, 08:39 PM
Supergrover's Avatar
Originally Posted by rjbarker View Post
Phil....
I dont know if it leaking since it doesnt seam to have the characteristics of a leak, a leak by and large starts out with xxxmb then starts leaking ( the rate can and will be different as per the leak) @ say 5mb (again depending on the leak ) per second and slowly adds up until your out of ram/vram.
BF3 doesnt seam to do this, I find that right off the hop I am close to or using all my vram (xfired 6970's but same poop different pile).
R.I.P.
Old November 12, 2011, 10:58 PM
rjbarker's Avatar
I'm not sure if its "leaking" either SG....really Sky explained it all very well, but its getting to "techy" for me ;) I do know that 3GB VRAM for 2560 x 1440/1600 is what I'll be looking at next for sure, would love to sell off my current Cards and get some 3GB versions now (now my 580's will still fetch a premium), but hhhmmmm, LGA 2011, PCI E 3.0 maybe with new GTX6xxx series....? Then I get actually playing games with my current Cards and think to myself wtf, I gotta be nuts as this gameplay is perfect ;)
MARK 11: 32.530
Old November 13, 2011, 10:57 AM
Jim's Avatar
Jim Jim is offline
wow yea I guess so,er uh what ?....side tracked by the avatar
what is a good Media player for a good price or any suggestions Shadowmeph HTPC Systems & Software 4 December 19, 2009 11:27 PM
good 1 day/bad another? frosty Water Cooling 6 November 3, 2008 12:35 PM
good enough? rellish CPU's and Motherboards 9 March 19, 2008 02:22 PM
Is my PSU good enough? SniperClops Troubleshooting 3 October 8, 2007 08:07 PM
DAM Good PSU BALISTX Power Supplies 9 October 4, 2007 11:38 AM
