Old November 11, 2011, 05:32 PM
CTA's Avatar
CTA CTA is offline
Default security camera card
i know its not exactly video card.. my brother wants to connect the security camera into his pc...
so any recommends (cheap is fine)...
here is the picture because we still cant figure the detail of it... i hope it will help....
Old November 11, 2011, 05:43 PM
sswilson's Avatar
I'm assuming that's a standard RCA jack? What kind of application does he want to do with the signal?
Without getting into anything specific, I'd think that pretty well any TV card with inputs would do.
Old November 12, 2011, 11:58 AM
CTA's Avatar
CTA CTA is offline
yes he wants software to record...
i will look for good card with rca jack... thanks...
Old November 20, 2011, 06:33 PM
i havent really seen cctv cameras with rca jacks on them. im more curious about what kind of camera it is. let me know what kind of camera it is and ill see what i can come up with for you.
unless you find something that will work for you, i know that a proper pci card, software ect usually runs around a couple to a few hundred dollars. it is what i do for a living. i assume you could always find a way around it. not sure what your application is. could always run it to an old time lapse recorder if thats what your after.
depending on how much you want to spend, some of the the new digital video recorders have apps that allow you to log in remotly and view from your phone.
i can only think that the rca jack on the camera once had a bnc connector that was cut off and replaced with the rca to plug into a tv to view from.
bnc connector used for cctv cameras
Old November 20, 2011, 06:36 PM
sorry about the giant picture. didnt realize the size
Old November 20, 2011, 07:31 PM
KaptCrunch's Avatar
more like this size its a BNC. but end installer used vicegrips to crimp on. looks if was decoy camera in store the RCA probly was power to flashing light
EMT security akirez64 Off Topic 6 October 5, 2010 11:19 PM
XFX Security Breach Results in Loss of Limited Edition Video Card FiXT Video Cards 18 April 25, 2010 07:52 PM
Looking to build low budget Security Camera System, any help? The MAX New Builds 5 July 7, 2009 09:43 AM
security camera computer CTA New Builds 52 March 22, 2009 07:23 PM
