Crossfire or single video card? Hi guys, im buying a pc in future just waiting for my money but I can't think about which card is best to have 2x sapphire HD6870 in crossfire ( price 150 euro each ) or 1x XFX HD6970 ( price 319 euro ) and which motherboard is best or is there another better motherboard Gigabyte GA-Z68XP-UD4 (€ 157,90*) or Gigabyte GA-Z68X-UD3P-B3 (€162,90*) I hope you can help me to get a good gaming pc greetings Buddy :) |
I say invest on the highest card (6970) as it will give you better performance than the 6870. 6870 is considered to be a mid range card and the 6970 the best single GPU card that AMD made. Edit: This is to avoid any possible (driver) problems you might encounter with CFX, But if you want higher scaling take the risk and go for the 6870. |
Tnx for your opinion :thumb: I like to see more opinions to have a better view about taking the good choice ( btw sorry for my bad english, im not that good @ it ) |
I think because this is a Canadian forum you'll see more as the day pass by and yes I also want someone to argue with me. |
also get Gigabyte GA-Z68XP-UD4 (€ 157,90*) That's a solid performing board, I had one and it did everything very well! |
Ok tnx I will :biggrin: |
6870s in CF will give more 'on paper' performance and better benchmark results, but a single 6970 will provide a more trouble free experience. (and less heat/noise/power draw) Just my 2 cents. |
IMO always get the best single card your budget allows for. This avoids the headaches of SLI/XFire, but gives you the option to add another card in the future if you find you need it or get a great deal. I would consider SLI/Xfire as an upgrade path down the road and not a plan to start with. |
I have 2 6870's and I wish I had bought a single card like a 6970 or gtx 570, 580. |
The only reason to have two cards,is if you have a 30 inch monitor. 2560x1600 or higher resolutions perform better with two cards. One good card will run anything else. |
| All times are GMT -7. The time now is 12:53 AM. |
