Old November 10, 2011, 04:59 PM
Apathetik's Avatar
Default Best 6950 to BIOS unlock to 6970
Can anyone recommend or link any of the 6950 cards that are best to be BIOS upgraded to 6970. I have read that I need a reference model of the 2gb version to unlock the BIOS to 6970 specs. If there is still the cards available to do so. MSI or XFX would be my ideal brands of choice, but I am fine with any.
Thanks.
Old November 10, 2011, 05:16 PM
Apathetik's Avatar
Also, how do you tell which cards are "reference cards" say on Newegg or NCIX for example?
Newegg.ca - MSI R6950 Twin Frozr II Radeon HD 6950 2GB 256-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card with Eyefinity
This above one apparently works great if you use the right version of Winflash. Can anyone else confirm this?
Thanks.
Old November 10, 2011, 11:31 PM
supaflyx3's Avatar
None of the current 6950's can be flashed too 6970's, you'll have to buy used.
Old November 12, 2011, 10:49 AM
You will have to check around online to find the serial numbers for the original reference cards because the later revisions have their shader cores laser cut so you cannot flash them to 6970 shaders
Old November 29, 2011, 06:34 AM
Apathetik's Avatar
Cool thanks for the info!
Old November 29, 2011, 08:07 PM
I just bought a new 6950 that can be flashed cuz I flashed it , diamond 6950 there's 6950 xoc it also has a dual bios switch, I posted pics on another post.
Diamond Radeon 6950PE52GXOC 2048MB GDDR5 PCI-E Video Card : Video Cards - Best Buy Canada
Old November 29, 2011, 09:09 PM
I've had 2 different 6950's from sapphire. A 1gb with the large single fan it didnt unlock, also didnt have the dual bios switch.
I do have a few of the 2gb Reference model, the single fan near the end, with the dual bios. They unlock just fine.
However I chose not to apply the full 6970 bios due to the different voltages it applies. I simply used the winflash utility to backup the original bios, and change the shader count. For some reason I couldnt get the winflash to write the new bios and found a dos based flash utility from techpowerup (RBE) that did the trick, i simply swaped the intended 6970 bios with the one I made in winflash.
AMD Radeon HD 6950 to HD 6970 Mod | techPowerUp
Have an A-1 day!
Old December 6, 2011, 09:55 PM
you will need to look for a used one with the reference design.
I just got a XFX 6950 2gb and the switch is not even there anymore and i talked to the xfx reps pretty sure all the new 6950 will not unlock.
check out this post though
ATI Diamond 6950 XOC
[FS] XFX 6950 2GB stuck at 500mhz, selling it cheaper, sold mckchun Buy/Sell & Trade 11 December 21, 2011 06:02 AM
Sapphire Toxic 6950 2GB Question - Preloaded with HD 6970 Bios? Zak_M Video Cards 2 August 24, 2011 08:06 PM
[FS] Intel 2500k SOLD, Sapphire 6950 with BIOS unlock SOLD wedge22 Buy/Sell & Trade 0 May 12, 2011 10:09 PM
Happy Holidays from AMD - Many Radeon HD 6950 Reportedly Unlock to HD 6970 mikellini Press Releases & Tech News 13 January 6, 2011 12:01 PM
AMD 6970/6950 On the Egg Chromey Video Cards 5 December 14, 2010 09:56 PM
