Old November 7, 2011, 05:39 PM
Originally Posted by Remf View Post
Ok!
When you say it's not that well regarded, is it about NOT having the 700W that it lists? Is it that they fail alot? Bad components?
Unfortunatly(or fortunatly) people tend to have a pretty good memory regarding failing PSUs. I think(really not sure) that OCZ has gotten better recently, but since they had some pretty big problems for a while people simply stopped buying them. I would say they are average, but definitively not something I would trust to be powering 2 GPUs.
Old November 7, 2011, 05:40 PM
Soultribunal's Avatar
Ok!
Cause most reviews I have read gave it a more than fair rating.
Its internals weren't the greatest,
There are much better designs out there that are less likely to kill components over time.
The new ZS series actually have good reviews from OCZ, but I would feel safer suggesting something from Antec, Silverstone, Superflower, Corsair over an OCZ unit.
-ST
Old November 7, 2011, 06:04 PM
Originally Posted by Kilauea View Post
If the card is registered, XFX offers lifetime warranty, unless I am mistaken. I'd definitively check it out.
Actually I'm pretty sure that XFX only offers 2 year warranty in Europe. I don't think any company in Europe offers lifetime warranty. In fact if google is translating some swedish sites correctly most graphic cards, xfx included, say Fabriksgaranti (mån): 24 - warranty (months): 24
Also, I've heard xfx doesn't deal with the consumers in Europe for warranty. The consumer has to go through their place of purchase, then the place of purchase deals with xfx.
This is all stuff you might want to check on before buying a graphics card. I know I like good quality but also good warranty srvice, so I go for either Asus or XFX. But it sounds like you might have to make sure you are buying from a store/site with a good reputation.
Hardware Canucks Rules!
Old November 7, 2011, 06:07 PM
-ST
Antec High Current Gamer 620W, would that work for single GPU?
Better than OCZ?
Would be great with some advice on specific PSU :)
EDIT: Would you take the Corsair TX 650W V2 over the OCZ?
It's the same price but NOT modular.
Will the Corsair TX 750W V2 run CF 6950?
Corsair TX 750W V2 - 895 SEK
Corsair TX 650W V2 - 735 SEK
Antec HighCurrent Gamer HCG 620-EC 620W - 595 SEK
OCZ Technology 700W ModXStream Pro - 669 SEK
(Prices in swedish kronor for comparison)
Old November 7, 2011, 06:15 PM
Better than OCZ?
The great thing about the companies listed, is that almost everything they offer is better than the OCZ.
Specifically,
The TX or HX or AX Series (depending on budget) by Corsair are perfect picks, no matter which one you can afford.
Antecs High Current Gamers are very good too.
Silverstone: Strider Plus are good models
Superflower: Golden Green
NZXT: HALE90
All of those I would choose over OCZ.
-ST
Old November 8, 2011, 01:37 PM
Then I will ask, what power do i need for a 6950+i5 750 setup?
Is 500 W enough or on the low end?
Old November 8, 2011, 01:49 PM
A quality 500W would be perfect.
ST
Old November 8, 2011, 01:55 PM
ST
The problem today is I have shitty 500W, don't want it to take the GPU down with it if it decides to give up (do you think it might have to do anything with my GTX 260 having problems with SC2?).
Don't know if I should buy a super-PSU and never have to buy one again.
Cause a Corsair TX 650W V2 won't be able to run 6950 CF?
  #19 (permalink)
Old November 8, 2011, 02:03 PM
A bad PSU that has fed low quality power to parts over time is one possible cause. No real way to know the culprit but bad power is high up there on the list. Which is why I don't take a chance and buy good units.
If you are going to do 6950 CF get a HX750. That will handle it.
You will always have to Buy PSU's (technology changes) just maybe not as often as other components.
-ST
  #20 (permalink)
Old November 8, 2011, 02:20 PM
-ST
I understand a HX750 won't last forever, but would 5-6 years+ be unrealistic?
PowerColor Releases Radeon HD 6870 X2 2 GB Graphics Card Sam_Reynolds Press Releases & Tech News 4 June 26, 2011 06:56 PM
HD 6870 Roundup: Diamond, PowerColor, MSI, Sapphire & XFX Comment Thread SKYMTL Video Cards 5 April 25, 2011 05:26 PM
Radeon HD 6870 HELP sankukai Video Cards 3 February 19, 2011 10:48 PM
