Old November 5, 2011, 09:20 AM
n0y n0y is offline
Default Asus Radeon 6970 DirectCU II crossfire
hey guys, is it possible to crossfire these 2 cards with my current motherboard and will it fit my casing? given the fact that they're space eaters? i'm planning to do this kind of setup. my current rig is:
CPU: AMD Phenom x6 1100t @ 4.11GHZ
MEM: 16gig GSkill 1600mhz cl8
GPU: Asus Radeon 6970 DirectCU II
MBoard: Crosshair V Formula
CPU Cooler: Corsair H80
PSU: Cougar CMX 700w
Casing: Thermaltake Armor A60
If its possible i am surely going to upgrade my psu, any recommendations? Thanks in advance guys!
Old November 5, 2011, 10:30 AM
Supergrover's Avatar
The DCII's will fit on that board using the top slot and the 5th slot, but the card is going to be tight to the bottom of the board.
Under load you will be getting close to the limit of 700w, a nice Seasonic or Corsair 850 would give you plenty of room.
If you already have 1 DCII then pop it in the bottom slot to get a idea of the size. Cfireing these is alot of room.
R.I.P.
Old November 5, 2011, 11:02 AM
n0y n0y is offline
hey Supergrover, thanks for the quick reply! and yeah will try to put the card on the 5th slot so that i can have an idea.
Asus 6970 direct cu2 - crossfire troubles CMetaphor Video Cards 17 October 19, 2011 03:55 PM
ASUS Rolls Out New Radeon HD 6770 DirectCU and HD 6750 Formula Cards Sam_Reynolds Press Releases & Tech News 0 May 10, 2011 11:38 AM
Asus EAH5850 Radeon HD 5850 DirectCU T or Asus ENGTX460 DirectCU GeForce GTX 460 1GB tfy Video Cards 12 February 23, 2011 11:42 AM
ASUS Radeon HD 5850 1GB DirectCu TOP Review Comment Thread SKYMTL Video Cards 20 September 12, 2010 07:15 PM
