-   -   GTX 570 and HD 5750 (http://www.hardwarecanucks.com/forum/video-cards/47897-gtx-570-hd-5750-a.html)
TheJewBucca November 2, 2011 06:14 AM
GTX 570 and HD 5750
So I'm getting a GTX 570 soon and was wondering if i could dual it with the card i have already which is an HD 5750.
Arinoth November 2, 2011 06:20 AM
No you can't. Not only can you not run sli/xfire with the two different major brands, you cannot sli or xfire outside of their own generation or sub generation. The only thing you could do is run the GTX 570 as a very expensive physx card for the 5750, which would be absolutely pointless.
LeadSled November 2, 2011 07:12 AM
A GTX 570 is 10X the card the 5750 is. It looks lie you need to read alot more about the hardware you spend your money on. It looks to me you upgraded from a XBox.
TheJewBucca November 2, 2011 07:38 AM
As I'm only a student i don't have a lot of money to buy stuff. when i first build my computer 2-3 year ago that the card i got so excuse me if i can't upgrade my card every year. so i was just simply wondering if i could combine the two cards there is no need for comments like that and yes i know i don't know alot about computers and i didn't build my computer i got a friend to pick the best parts for what money i had at the time.
Kilauea November 2, 2011 08:44 AM
As others have said, you can't combine both cards. The 5750 is a decent card, but its clearly a card which is limited. The 570 on the other hand is among the top that you can get at the moment. And while it is a very good card, I wouldn't recommend it in your situation. You would most likely be better served with a GTX 560 ti or a GTX 560 which will cost a decent bit less and perform much better than what you currently have.
However, before going and suggesting anything, it would be wiser to go and ask about what you have. If you don't know, you can always ask your friend.
What Power supply do you have ?
What CPU do you have ?
How much memory(RAM) do you have ?
What case do you have ?
What games do you play ? at which resolution ?
What is your budget ? (my understanding is that you have quite a limited one, so you want a good price/performance compromise)
With at least those informations, the suggestions you will get will be much better aimed at your desires.
TheJewBucca November 2, 2011 08:57 AM
power suppler:Apevia Warlock Power 900W
cpu:Intel(R) Core(TM) i7 CPU 920 @ 2.67GHz (8 CPUs), ~2.8GHz
memory: 8Gb
case:Lian-Li LanCool PC-K62
games: i play a lot of different games but im going to buy bf3 which if why want to upgrade also for skyrim
Budget: is around $450AUSD
ilya November 2, 2011 09:21 AM
Aside from the PSU, you have a pretty good system. I'd get one that won't potentially damage your hardware before investing in new hardware though. Then I'd look at something like a used 570/580/6950, new cards are just aroudn the corner.
Those Apevia's are notorious for sparking and smoking. You definitely won't need a 900W unit either, a quality 500W unit will do.
Since you're not in Canada it would help to know what options you have down under so we can give suggestions.
Kilauea November 2, 2011 09:22 AM
memory: 8Gb
For the PSU (power supply), I don't know much about that brand, so I will place it into the category of the try to change for a known good brand (aka Antec, Corsair, Seasonic), unless someone confirms its trustworthy.
The rest of your computer is quite decent... actually overkill for a 5750. Going for a 570 is a good choice to be able to play BF3 at high settings at 1080p, a GTX 560 ti would possibly be enough for that too, but that would be the minimum without lowering details. On AMD's side of things, you'd want a 5870 or a 6950 at least for high details 1080p. If you play at a resolution lower than 1080p, nvidia handles ultra quality better than AMD, but you'd want to stick with the GTX 570.
TheJewBucca November 2, 2011 09:36 AM
i guess i have the same options as you would in Canada but just different pricing
TheJewBucca November 2, 2011 09:38 AM
ok good to know i got it free when i bought my case so thats really the only reason i have it.
