Old November 2, 2011, 09:42 AM
Soultribunal's Avatar
Originally Posted by Kilauea View Post
For the PSU (power supply), I don't know much about that brand, so I will place it into the category of the try to change for a known good brand (aka Antec, Corsair, Seasonic), unless someone confirms its trustworthy.
The rest of your computer is quite decent... actually overkill for a 5750. Going for a 570 is a good choice to be able to play BF3 at high settings at 1080p, a GTX 560 ti would possibly be enough for that too, but that would be the minimum without lowering details. On AMD's side of things, you'd want a 5870 or a 6950 at least for high details 1080p. If you play at a resolution lower than 1080p, nvidia handles ultra quality better than AMD, but you'd want to stick with the GTX 570.
I would get something other than the Apevia as well.
They are terrible units.
Corsair, Antec, Silverstone, NZXT HALE 90's, Superflower Golden King, Kingwin Lazer Gold would be good ones to consider,
ST
www.realhardwarereviews.com
Old November 2, 2011, 11:13 PM
ST
Would you recommend buying a new one before i getting the card or do you think it would be safe running my current PSU with an GTX 570
Old November 3, 2011, 01:38 AM
FlyingFish's Avatar
Personally, I'd get a new one before running the card just to be on the safe side. I've only ever lost 1 machine to a crap power supply. It killed the motherboard, but fortunately it was a work machine so it got replaced.
This is my signature. There are many like it, but this one is mine. My signature is my best friend. It is my life. I must master it as I must master my life. My signature, without me, is useless. Without my signature, I am useless.
Old November 3, 2011, 03:42 AM
If you can easily afford to purchase another PSU and whatever parts it might bring along with it, then u can wait... but then again, if you can afford that, why not do it now ?
If you can't afford to have loss, then if you need to delay your graphic card for a new power supply, do it; otherwise you might be stuck with a paper weight for some time.
to xfire my 5750 or buy new muffler Video Cards 9 July 15, 2010 03:50 PM
5750 + 5770 In Crossfire ? CoolHandL Video Cards 2 April 13, 2010 02:17 PM
Sapphire 5750 r0k0 Video Cards 9 January 27, 2010 04:52 PM
5750 or 9800gtx muffler Video Cards 4 January 19, 2010 09:24 AM
5750 Information Iphikratous Rumor Mill 2 October 8, 2009 02:46 PM
