Old November 1, 2011, 01:02 PM
Beastylemon's Avatar
Question GTX 570 SLI vs. GTX 590
What do HWC?
$600 for SLI or $700 for Single??
Dunno what to do with the 570's after GTX600 launch =\
I would sli the 590 later, but I've never gone quad sli =\
Corsair 650D / ASUS P8Z68 Deluxe / Intel i7-2600k / MSI N580GTX / 4X4 Gig Corsair Vengeance DDR3-1600 / OCZ Agility 3 120GB / Corsair H100 / Corsair AX1200W PSU
ASUS VE247H / Razer Black Widow Ultimate Stealth Edition / Razer DeathAdder /Razer Destructor Mousepad
Old November 1, 2011, 01:06 PM
Arinoth's Avatar
You have to ask yourself which will you have longer. If you think it would be the 590 and sli'ing it later then go that route. If you think going 2 570s then going to kepler, I'd go with the first.
Old November 1, 2011, 01:28 PM
True, what do you think will be easier to sell after the kepler? 2 570's or 1 590?
Old November 1, 2011, 01:30 PM
Arinoth's Avatar
They will both be easy to sell, the main question is which is going to depreciate in value more. That I have no idea, depends on how much kepler can beat them
Old November 1, 2011, 01:37 PM
yycraven's Avatar
But wouldn't the GTX 570's lose more value then the GTX 590, when the Kepler cards come out.
Even if the Kepler's are 10% faster you know people will buy them.
Also doesn't a single GTX 590 3GB beat GTX 570 SLi. Maybe I am wrong.
ASRock Extreme 3,2500K,NH-D14,Patriot G2 16GB ,WD 750GB,640GB Sata ,2 GTX 470 SLi Thermaltake toughpower XT850W,Tech Station. V243H,2253LW LCD
heatware
Old November 1, 2011, 02:03 PM
Soultribunal's Avatar
The 590 is what I would opt for, Sometimes single card solutions with dual GPUs are better bet.
Resale will be much better I think on a 590. Much like how resale value stayed high for the GX2's long after there time had come and gone.
ST
Old November 1, 2011, 03:39 PM
GTX 570 SLI beats a GTX 590. Also, you would lose quite a lot more on buying a GTX 590 once the GTX600 series launches because that card is priced so high.
Also, Quad SLI does not scale well at all, often it is beaten by Tri-SLI. Tri-SLI is currently the best config.
http://www.heatware.com/eval.php?id=21074 80-0-0
HTPC Rig: E3300 @ 3.5 GHz | Foxconn Blackops x48 | 8GB Kingston HyperX | 1TB WD Blue | Seasonic X560 | Corsair 650D | Sapphire 4870 1GB | Samsung 50" Plasma | HD280 Pro
Gaming Rig: 2500K | Noctua NH D14 | Asrock Extreme4 P67 | 8GB Gskill | 1TB WD Black | Corsair AX750 | Silverstone FT02B | EVGA GTX 580 1.5GB | Dell U3011 | Edifier s5.1
Old November 1, 2011, 03:50 PM
yycraven's Avatar
But even being that the GTX 590 is a dual GPU, would think it would beat the two GTX 570's
heatware
Old November 1, 2011, 03:52 PM
supaflyx3's Avatar
GTX 590 = 2 580's toned down quite a bit to meet the thermal and power regulations. So basically 2 570's.
Old November 1, 2011, 04:09 PM
590 stock clocks are 607/1215. the 570's are 732/1464
Fps comparison here for the 590 vs 570
Equilibrium: AMD Radeon HD 6990 vs. Nvidia GeForce GTX 590. Page 7 - X-bit labs
