Originally Posted by Arinoth Have you tried running the card by itself? If not they'll ask you if you try to RMA and more then likely tell you to try the card by itself, as the reason your card is running hot is due to what I just said above and not a defective card. |
Thanks for the tip on the fan profiles. I'll check that out. I have tried running the Hawk on it's own and the temps still get up to 85-90C under load. I don't find that acceptable. Especially considering my Gigabyte card runs around 65-70C under load on its own. Certainly the Twin Frozr cooler isn't 20C worse than the Windflow cooler on the GB card?
