<~----> graphics card help - Hardware Canucks
Old October 25, 2011, 07:30 PM
Default graphics card help
I am new at building computers so I dont know which graphics card is best for its price. I was looking at the gtx 560. Is this a good card and will it get good frame in game?
EVGA 02G-P3-1469-KR GeForce GTX 560 Superclocked Video Card - 2GB, GDDR5, PCI-Express 2.0 (x16), 2x Dual-Link DVI-I, Mini-HDMI, DirectX 11, Dual-Slot, SLI Ready, Overclocked at TigerDirect.com
what card do you reccomend for around the price of 250$?
Old October 25, 2011, 07:42 PM
I would go for the GTX 560 Ti instead of the 560... You can get a 1 Gb version for roughly the same price:
EVGA GeForce GTX 560 Ti Fermi 850MHZ 1024MB 4104MHZ GDDR5 2XDVI Mini-HDMI PCI-E Video Card - DirectCanada
Old October 25, 2011, 07:48 PM
ok but what I dont understand is that both have almost the same spec it looks like execpt the stream proccessor on the 560 fermi is a bit higher but the 560 has 2gb so what the differnce. Is stream proccesor better then more video ram?
Old October 25, 2011, 08:12 PM
The 560 is just a cut down version of the 560 Ti (less signal processors) and is similar in performance to the older GTX 460. Unless you are running multiple monitors or very high resolutions 1 Gb should be adequate... I'd go for the higher performing 560 Ti. 2 Gb versions are available but are considerably more expensive (about $50. more). Depends what you need...
Old October 25, 2011, 09:21 PM
thank you for the help.
based on your info I think I will go for the GeForce GTX 560 Ti 2GB. You think this will handle the new games comming out like battlefield?
Old October 26, 2011, 12:02 AM
I'll make this easier for you.
get the ASUS gtx560ti DCII, it runs A LOT cooler, faster, looks better, quality is better, overclocks better. and will run bf3 high/ultra settings. plus it comes with free $50 batman arkham city game which is awesome
http://www.newegg.ca/Product/Product.aspx?Item=N82E16814121425
OR
get the MSI 560ti HAWK which is very popular choice as it has the highest core clock rating for 560 and can overclock even higher, runs cooler, this card was out of stock yesterday and it just came back in stock so i would jump on this before its sold out again.
NCIX.com - Buy MSI GeForce GTX 560 Ti Hawk OC 950MHZ 1GB GDDR5 Dual DVI Mini-HDMI DX11 PCI-E Video Card - MSI/MicroStar - N560GTX-Ti HAWK - in Canada
both cards will run bf3 maxed out no problem.
2gb version is not only limited but barely does any performance improvement.
and why buy from tigerdirect? lol?
Old October 26, 2011, 04:18 AM
What resolution do you game at?
My vote would go to a 1gb 560Ti
Desktop: X3 710, 4GB DDR2 1066, MSI Cyclone GTX 460, Seasonic S12II 500W
Away from home light Gamer: Acer Aspire 15.6", A8-3500m, 4GB 1333
Internet/General Use: Lenovo B570 15.6", i3 2330m, 4gb 1066mhz
Old October 26, 2011, 04:32 AM
Meta|Gear's Avatar
I don't think a 2gb model is worth it. you will see very little performance increase if any. 1gb is sufficient @ 1920x1080.
560 ti 1gb @ newegg for $219
Newegg.ca - GIGABYTE GV-N560UD-1G GeForce GTX 560 Ti (Fermi) 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
RFD
Intel i5 2500K @ 4.5 | Corsair H50 | Gigabyte GA-Z68X-UD3H | 8GB G.Skill Sniper 1600Mhz | SLI GTX 460 768MB | Antec High Current Gamer Series 900W
Kingston 64GB V100 - WD Black 500GB - WD Green 1.5TB | CM HAF 922 | Asus VW246H
| Logitech G15 v2 | Logitech G9x
| Steelseries Siberia v2
Old October 26, 2011, 07:46 AM
Alright I guess I'll go with one of the gtx 560 ti fermi. Thank you all for the advice.
Old October 26, 2011, 09:46 AM
Last time, I checked, there's a PNY 560 Ti 1GB available for $195 incl. rebate.... it's the cheapest and the best deal. The PNY card also has a lifetime warranty.
Buy it at NCIX PM'd @ $225 and then you get a $30 rebate. I don't like rebates but it's still the best deal, imho. As long as it lasts, though.
Is graphics card X more or less powerful than graphics card Y Linus LinusTechTips Q&A 1 October 4, 2011 05:50 AM
New graphics card Sevada Video Cards 17 September 28, 2011 08:46 PM
Intel HD Graphics with Graphics Card MoUnit CPU's and Motherboards 4 August 6, 2011 03:54 PM
AMD Extends Graphics Performance Lead, Launches World's Fastest Graphics Card? Again! FiXT Press Releases & Tech News 2 March 8, 2011 02:32 PM
Best graphics card for ~100$ Bubbzilla Video Cards 8 September 6, 2010 09:55 AM
