<~----> A little advice? :D - Hardware Canucks
Old October 24, 2011, 10:39 AM
Trial Member
Exclamation A little advice? :D
Hello. I'm debating on weather i should get the EVGA GTX 580 or GTX 570 because i'm a little over my budget.
Is there really a BIG difference between the two video cards? I just want to save 100 bucks so ya.
Also, do you know any good gaming monitors for under $200? I found this one but i want to know if its right for me.
LG W2343T-PF, 23" Widescreen HD LCD - 1920 x 1080
Thanks for helping! :D
Old October 24, 2011, 11:17 AM
Soultribunal's Avatar
If you are over budget then grab the 570. Though personally speaking I feel the 580 would be worth the extra cash. Espicallty for single card gaming.
http://img.ncix.com/images/53304_l.jpg
And while on sale, get this monitor. I use one of them at home, and I have no issues with gaming. Not the best of the best, but on a budget it works great.
ST
Old October 24, 2011, 01:06 PM
Here is a performance summary. In this chart ($1500 asus mars II dual gtx 580 is the baseline) the 580 is 6% faster than a 570. IMO the 580 is better, but the 570 is better bang for buck. I will leave the decision if it is worth the extra money to you.
Desktop: X3 710, 4GB DDR2 1066, MSI Cyclone GTX 460, Seasonic S12II 500W
Away from home light Gamer: Acer Aspire 15.6", A8-3500m, 4GB 1333
Internet/General Use: Lenovo B570 15.6", i3 2330m, 4gb 1066mhz
Old October 24, 2011, 03:09 PM
yycraven's Avatar
Would go with the GTX 570 still a good card for the $ and will do fine with that LCD.
IMO!
ASRock Extreme 3,2500K,NH-D14,Patriot G2 16GB ,WD 750GB,640GB Sata ,2 GTX 470 SLi Thermaltake toughpower XT850W,Tech Station. V243H,2253LW LCD
heatware
Old October 24, 2011, 11:49 PM
Would you post the resolution mentioned by Chris (1080) or just copy us a link to this page?
Old October 25, 2011, 03:59 AM
I usually just open the latest video card review from techpowerup and go to performance summary as it includes the newest reviews and GPU. They don't review at 1080p, but there is 1920x1200 if you interested.
ASUS Mars II 3 GB Dual GTX 580 Review - Page 27/31 | techPowerUp
Old October 25, 2011, 05:43 AM
Meta|Gear's Avatar
I'd save the $100 and just get the 570
RFD
Intel i5 2500K @ 4.5 | Corsair H50 | Gigabyte GA-Z68X-UD3H | 8GB G.Skill Sniper 1600Mhz | SLI GTX 460 768MB | Antec High Current Gamer Series 900W
Kingston 64GB V100 - WD Black 500GB - WD Green 1.5TB | CM HAF 922 | Asus VW246H
| Logitech G15 v2 | Logitech G9x
| Steelseries Siberia v2
Old October 25, 2011, 12:59 PM
Pabz0r545's Avatar
I'm sure you will be pleased with a 570. Plus down the road you can just add a second one if you feel you need more firepower.
Old October 25, 2011, 08:54 PM
personally, i was in the same boat as you, my gpu wasn't holding up anymore so I was in the market for a new gpu for now and then purchase a whole new hardware (cpu+mobo+mem) later as my oc'd e8400 won't be much of a bottleneck in today's standards.
So I asked myself...which one would benefit me the most? buying a 560ti, 570 or the almighty 580?
I searched around and found out that for me, 560ti is a really good card for the money, but it really doesn't have the performance edge that I needed and I wouldn't mind spending an extra buck or two to get something better.
so then I looked at GTX570 (specifically the MSI gtx570 twin frozr iii and the asus gtx570 dcII).
my final decision was the MSI gtx570 twin frozr iii because you can easily overclock this thing to gtx580 speed for the price of a 570, I think that was the best bet for me.
Tags
advice , monitors , nvidia 570 , nvidia 580
advice please kalvinjones Off Topic 8 July 22, 2011 12:57 PM
Need some advice HiTi New Builds 4 January 9, 2011 02:45 PM
gpu advice CTA Video Cards 23 December 29, 2010 01:44 PM
car advice... omgwtf Off Topic 42 September 8, 2009 10:41 AM
Need Advice !! Gogoune Power Supplies 2 April 16, 2008 03:53 PM
