-   -   Asus AMD Radeon HD6770 DCU Ram clock (http://www.hardwarecanucks.com/forum/video-cards/47521-asus-amd-radeon-hd6770-dcu-ram-clock.html)
ghotichoooder October 21, 2011 12:45 AM
i juz wondering that anyone could answer why my GPU Asus AMD Radeon HD6770 DCU ram clock is lower than its twin Asus AMD Radeon HD6770 with no DCU...my GPU has 1GB DDR5 with 4000MHZ while normal HD6770 Asus has 4800MHZ?...doesn't this make my GPU has lower perfomance?
GT7R October 21, 2011 02:51 AM
Since your card has 128 but memory bus the memory speed is kinda critical, but since it's a mid range card it really depends on your specific scenario (game, resolution, other system components, etc). You can try overclocking the card and it's memory with MSI Afterburner - you should be able to raise both clocks by 10% without increasing the voltage (just remember to set the catalyst power tune to max performance).
ghotichoooder October 23, 2011 12:32 AM
why MSI afterburner?...i got SmartDoctor asus software...can't it be used for O.C my GPU?...
GT7R October 23, 2011 12:41 AM
It can, but I've never used it, so Afterburner could be my best advice :)
supaflyx3 October 23, 2011 12:46 AM
I would also suggest afterburner, awesome and simple utility.
ghotichoooder October 23, 2011 12:48 AM
ok...then MSI afterburner will be used:biggrin:....
ghotichoooder November 9, 2011 10:06 AM
can anyone show me how to use MSi afterburner?
