<~----> XFX 6970 Temperature Question - Hardware Canucks
Old October 20, 2011, 11:15 AM
Default XFX 6970 Temperature Question
Hey guys I have a Question about the temp on my new 6970, it idles at around 50C and when gaming goes up to around 80~85C, is that a reasonable temp?
Old October 20, 2011, 11:21 AM
Arinoth's Avatar
What kind of case are you using, do you have any case fans, and are you using the default fan profile?
Old October 20, 2011, 11:38 AM
It is a tad high, for example my GTX 560 ti twin frozr II runs at 30 idle and 55 load... Even without a custom cooler you shoulkdn't be that much hotter than mine.
Old October 20, 2011, 12:10 PM
Meta|Gear's Avatar
from the reviews I have read 85-95c seems to be the norm for these cards.
AMD Radeon HD 6970 Review > Power Consumption & Temperatures - TechSpot Reviews
RFD
Intel i5 2500K @ 4.5 | Corsair H50 | Gigabyte GA-Z68X-UD3H | 8GB G.Skill Sniper 1600Mhz | SLI GTX 460 768MB | Antec High Current Gamer Series 900W
Kingston 64GB V100 - WD Black 500GB - WD Green 1.5TB | CM HAF 922 | Asus VW246H
| Logitech G15 v2 | Logitech G9x
| Steelseries Siberia v2
Old October 20, 2011, 01:43 PM
uwish's Avatar
my xfx 6870 sits around 50C idle but I have only seen it up to 60 C after gaming.
AMD 1090T @ 4Ghz
Thermalright Venomous X RT cooler
AMD M5A99X EVO MB
4GB DDR3 RAM
XFX Radeon 6870
Coolermaster Haf X case
>3 TB storage
dual Samsung 22" widescreens
Old October 20, 2011, 02:56 PM
i have the Corsair 650D, it comes with three case fans. and yes I'm using default.
Yeah i read that too in some reviews but I just wanted to make sure. i guess they just run significantly hotter than performance cards. Also keep in mind this is with everything set on max on all my games.
Old October 20, 2011, 02:58 PM
the 560 usually doesn't use much heat and on top of that you have the Twin Frozr version which from what i hear that whole line of products run pretty dam cool.
Old October 20, 2011, 03:19 PM
tianfeng's Avatar
My xfx 6950 use to idle at 50 and game in the high 80's. but a custom cooler and I idle at 33 and game at high 40's low 50's. this is overclocked as well.
Old October 20, 2011, 04:36 PM
your temps are perfectly fine. The corsair case is not very good for air cooling, it just doesnt provide anough airflow (especially with stock fans).
And stop comparing temps of a high perfomance card such as 6970 with lower end models.
Old October 20, 2011, 07:35 PM
Arinoth's Avatar
Your temperatures are fine then, though I'd recommend following the tutorial in my signature if you want your card to run cooler when idling or at load
Temperature question ( which temperature do I go by? Shadowmeph Overclocking, Tweaking and Benchmarking 3 August 19, 2011 01:00 PM
6970 temp question ultraman7k Video Cards 5 May 23, 2011 10:49 AM
[Question] Temperature gaha885 Overclocking, Tweaking and Benchmarking 11 November 12, 2010 09:29 AM
Core i7 temperature question xXxRithxXx CPU's and Motherboards 19 June 25, 2009 02:44 PM
Overclocking temperature question CORE Overclocking, Tweaking and Benchmarking 6 May 22, 2009 01:44 PM
