Old October 19, 2011, 04:16 PM
Default What is the difference between 4400mhz vs 4200mhz
Im looking for a 2nd gpu and my is at 4400mhz(memory) if i get 2nd one and it's a 4200mhz what will happen and can i jsut overclock them both to 4400?
Old October 19, 2011, 04:20 PM
ZZLEE's Avatar
Witch cards SLI or Crossfire
MSI Afterburner could be your friend.
"EVGA hunted down the last dozen or so expats living in Karachi." SKY
Old October 19, 2011, 10:57 PM
bradleyg5's Avatar
I mean the performance difference will be pretty tiny. the thing is in my experience the ram on graphics cards is very intolerant to 24/7stable overclocks. Your 1st card probably has really good ram modules that accept overclocks. like the same type and rated speed they just happen to be ones that allow overclocking.
I'd say the chances of buying 4200mhz ram and getting it overclocked to 4400mhz would be low. Unless your changing voltages and stuff. probably better to expect them both clocked to 4200mhz
O/C Difference lechumbl Overclocking, Tweaking and Benchmarking 13 September 25, 2011 04:39 PM
difference between MCB 655-b vs MCB 655-01 hatabilly0204 Water Cooling 8 April 25, 2010 11:44 AM
Wow, What a difference! Cowboy Video Cards 14 January 18, 2010 03:02 AM
is there a difference gingerbee O/S's, Drivers & General Software 0 December 9, 2009 09:44 AM
Wow.. Big difference Infiniti Water Cooling 8 December 25, 2007 07:24 PM
