Old October 18, 2011, 06:27 AM
Beastylemon's Avatar
Question Accelero XTREME Plus II
I have a pair of GTX 480's running in SLI.
They are in my 1st and 4th slot.
Would putting Accelero XTREME Plus II's on both my cards require a mega long SLI bridge?
Would it have to climb over the heatsink/cooler? Or would nothing be in the bridges way?
Corsair 650D / MSI Z77A-G45 / Intel i7-2600k / ASUS GTX780 / 4X4 Gig Corsair Vengeance DDR3-1600 / OCZ Vertex 4 120GB x2 / Corsair H100 / Corsair AX1200W PSU
Samsung U28D590D + ASUS VN248H x 3/ CM QuickfireTK MX Blues / Razer DeathAdder /SteelSeries 4HD
Old October 18, 2011, 06:37 AM
i think that you should position them in 1st and 2nd pci slot
Case: Cooler Master HAFX
Grafics Card: Gainward gts250 1024mb ram
Ram: Corsair 4gb dominator ddr3 1333Mhz
PSU: Corsair 850tx
hdd: sata 2 500gb
mb: asus P5QC P45
CPU: intel core 2 qaud q8400 @ 2.66 Ghz
Old October 18, 2011, 06:53 AM
I cant, the 480 is a dual slot.
so i WOULD put them in 1st and 3rd, but there is no pci-e slot in 3rd, only in 4th.
i hve the ASUS P8Z68 Deluxe
Old October 19, 2011, 05:15 PM
Just installed and sli works. I'm getting 80degree temps with the first gpu. is this because its right next to the second card?
Also i know the heatsink is attached cuz it gets hot. real hot.
Old January 6, 2012, 09:26 AM
Did you ever solve your heat problem? i got another accelero for my 2 gtx 580s and my first card is 84c while the bottom card is 62c. these are right next to each other and i dont have room to move the other card
Arctic Cooling releases the Accelero XTREME Plus II Gav Press Releases & Tech News 3 May 27, 2011 01:42 AM
[FS] Arctic Cooling Accelero XTREME 4870X2 AmuseMe Buy/Sell & Trade 15 January 16, 2010 08:04 AM
Accelero XTREME GTX yycraven Air Cooling 29 July 9, 2009 04:04 PM
Accelero Xtreme 4870X2 Eagle Eye Air Cooling 2 May 21, 2009 05:38 PM
Arctic Cooling Accelero Xtreme Kopi Rumor Mill 5 November 28, 2007 10:19 AM
