Old October 10, 2011, 02:26 PM
Default Heat increase in 5850
Well my PowerColor 5850 is just around 2 years old & im noticing the last few weeks now that my gpu temps have increased by about 3-4 degree's now in the low 40's .... think the thermal paste is goin ?
thanks
Old October 10, 2011, 02:32 PM
Keywork's Avatar
Probably not the thermal paste. It's been surprisingly warm these last couple weeks so an increase in ambient temps in your room could be the culprit.
Old October 11, 2011, 05:45 AM
krazyups's Avatar
Just keep following the trend: if it stabilizes or drops now that the weather has cooled off a bit, then Keywork has it nailed. However, if you still see the temps slowly climbing over the next few weeks, then you probably caught the very start of your thermal paste hardening.
In any case, it may not be a bad idea to change out the paste if it's been ~2 years.
Folding with rig under My System Specs, GTX460 in the kids' computer and whatever my dad can contribute.
Old October 11, 2011, 06:14 AM
Arinoth's Avatar
Also, if you've never blown compressed air on the card, dust build up on the fan and the heat sink will cause the card to not cool off as well as it use to.
Old October 11, 2011, 08:00 AM
Well i have it always running in max CCC since i've owned it ...
I currently have the fan idling @ 30% & its sitting @ 42c idle with the window open in a sub basement of a home ... its as of the last probly 2-3 weeks been having higher temps & i have to asume the age of the card is the cause more then the latest revisions of the catalyst drivers.
I have blown both compressed & vacume air thru it over the years cause of that fact.
Old October 11, 2011, 09:39 AM
ern88's Avatar
Ya, mine is idel at 40 C as well.
Old October 11, 2011, 12:51 PM
yycraven's Avatar
It wouldn't be a bad idea to change the paste and clean the the fan. Since it has been 2yrs now.
ASRock Extreme 3,2500K,NH-D14,Patriot G2 16GB ,WD 750GB,640GB Sata ,2 GTX 470 SLi Thermaltake toughpower XT850W,Tech Station. V243H,2253LW LCD
heatware
Old October 11, 2011, 01:10 PM
Arinoth's Avatar
You could try changing the paste, cleaning the fan, and perhaps re-greasing the ball bearings within the fan, the ball bearing grease can dry up over time causing your fan not to spin as efficently.
Old October 12, 2011, 10:30 AM
thanks for the thoughts/help, I think I'm gonna try the cleaning route for shure .... good thing I got onboard video still as a backup ... :P
Increase DRAM clock, huge increase in CPU temps? lowfat CPU's and Motherboards 12 September 7, 2011 10:56 AM
Do I need to increase the voltage Lanboy RAM 2 May 29, 2011 10:44 AM
Triple crossfire 5850 - heat issue at full load Asad_A203 Video Cards 19 May 22, 2011 03:18 PM
[FS] MSi 5850 and Sapphire 5850 *BOTH SOLD* wedge22 Buy/Sell & Trade 8 January 5, 2011 01:37 PM
how to increase the performace of.... Rescue119 Video Cards 0 April 20, 2010 03:58 PM
