Old October 7, 2011, 08:42 AM
Varroa's Avatar
Default Scaling issue (overscan?) after boot
Hey Guys, I've got a strange problem that I haven't been able to figure out on my own so far. When CCC 11.9 came out I upgrade (to fix a problem with a game) and since then, when ever I reboot my PC, the desktop is stretched out to about 4x the size of the screen (it doesn't fit on the monitor and you can only see about 1/4 of the screen)! The screen resolution still reads native (1980x1200) and the only way to fix it is to reduce the screen resolution to something below native, accept changes and then change the screen resolution back to native. After that everything works fine. Any ideas? I used drivercleaner pro between each driver upgrade and I even tried upgrading to 11.10 the other day and it still does the same thing. System specs are below and the monitor is a Dell U2410 connected by DVI. Thanks
GAMER: Win10 Pro x64, I7 3770K (4.7Ghz) (corsair H110i), Asus P8Z77-V Pro, EVGA GTX 1080 FTW, Gskill 2 x 8 GB DDR3 1600Mhz, Crucial M4 120 GB + 256GB, Crucial M500 480 GB SSD, Mx 500 SSD, HX750W, Sound blaster Z, & Fractal Design Arc MIDI R2
Lenovo Ideapad Y510p: i7-4700MQ 2.4GHz (undervolted by 80mV), 16GB DDR3L-1866MHz, Intel GMA 4600HD / SLI'ed Nvidia Geforce GT 755M 2GB GDDR5, 240 GB Crucial SSD, 128GB M.2 SSD, 15.6" HD+ Glossy LED
Old October 7, 2011, 06:14 PM
MARSTG's Avatar
maybe an older driver would fix the issue, try 11.5 or 11.6 or even older
Old October 8, 2011, 04:11 PM
Varroa's Avatar
I am stuck on the current version because one of the games I play crashes with anything lower.
Samsung 2333sw Overscan Display Issue GameOnTurtle Display Units 4 May 19, 2010 03:54 PM
Very Odd Boot Issue NES O/S's, Drivers & General Software 2 November 1, 2009 10:59 PM
Cold Boot Freezing issue. Sheep O/S's, Drivers & General Software 66 June 2, 2009 06:28 PM
X58 / I7 Cold Boot Issue rjbarker Troubleshooting 10 March 21, 2009 11:28 AM
EVGA X58 OC'ing boot issue kruzn4evr CPU's and Motherboards 6 February 6, 2009 09:49 PM
