Old October 6, 2011, 02:36 AM
I_need_a_new_RIG's Avatar
Exclamation 6670 problem
Hey guys jeah i just bought this card and i have a problem annoying huh?
My problem:
So when i put this card in it ran fine out he box i got a huge fps jump in games but then it went missing??
Like i was getting only 7 fps average over my 9500gt ddr2 i was shocked.
2nd problem when i watch videos i get these 3 lines appearing in the video heavy when theres alot happening! (it also appears in games not so heavy tho) I have vsync forced on in catalyst manager and in the game what could be the problem?
Update: so i left my pc then the next day i started it up it my screen refreshed and then everything looked so much better?? and what do you know my fps jumped up so much i am now getting:
27 fps average max 31 min 17 in Dragon age on 1600 by 900 res 60 hz at Dx11 Vsync on and all high and aa 2x and af 4x, so jeah major increase im happy but the lines are stil there
What i have tried:
Reloading my drivers twice
Checking my psu if it not broken
Checked my screen its 7 months old so i doubt it
Forced Vaync on
Please help me
What i think the problem is:
My board is a intel foxconn g31mxp-k with a pcie x16 port. The card says its 2.1 and my board says 2.0 could that be the problem?
Old October 6, 2011, 05:33 AM
Varroa's Avatar
What are your temps like?
GAMER: Win10 Pro x64, I7 3770K (4.7Ghz) (corsair H110i), Asus P8Z77-V Pro, EVGA GTX 1080 FTW, Gskill 2 x 8 GB DDR3 1600Mhz, Crucial M4 120 GB + 256GB, Crucial M500 480 GB SSD, Mx 500 SSD, HX750W, Sound blaster Z, & Fractal Design Arc MIDI R2
Lenovo Ideapad Y510p: i7-4700MQ 2.4GHz (undervolted by 80mV), 16GB DDR3L-1866MHz, Intel GMA 4600HD / SLI'ed Nvidia Geforce GT 755M 2GB GDDR5, 240 GB Crucial SSD, 128GB M.2 SSD, 15.6" HD+ Glossy LED
Old October 6, 2011, 06:07 AM
ttp://imageshack.us/photo/my-images/40 ... tress.png/ heres y temps they are fine i think
Old October 6, 2011, 07:17 AM
Varroa's Avatar
Use GPU-z and log your GPU temps while gaming to see how high they go.
Old October 6, 2011, 07:28 AM
i did i posted the image there it hits 51 degrees under stress i tested using hwinfo 32 and played bad company 2 for about 2 hours.
Old October 6, 2011, 07:40 AM
Varroa's Avatar
System specs? OS version? Drivers version? Did you clean your drivers out before installing the new card using something like drivercleaner pro?
Old October 6, 2011, 08:10 AM
My system:
System:
Intel Foxocnn G31 mxp board Latest Bios
Intel Celeron e1500 Duacl Core 2.20 ghz intel heatsink
2Gigs ram 677mhz
320 gb sata 2 hdd
ide dvd rom
450 watt psu
1 x RED Coolermaster RD Fan 8cm 1X BLUE Coolermaster RD fan 12cm
MSI R6670 1gig GDDR5 800mhz 4.0ghz
Windows 7 ultimate 32 bit
And Catalyst 11.10 latest from guru 3d.
I did not use driver sweep i uninstalled it the manual way do u think i should try driver sweep?
Old October 6, 2011, 08:53 AM
so i used driver clean pro v1.5 and i removed everything from nvidia to ati and the problem is still there
heres more information on this from another forum:
Forums | G3AR • Login
Old October 6, 2011, 08:55 AM
Varroa's Avatar
That is probably your problem. When you switch from an Nvidia card to an ATI you really need to run drivercleaner pro (it is free). Install the program, uninstall drivers, boot into safemode and remove ALL Nvidia options, reboot, install ATI drivers.
Download Driver Cleaner Pro v1.5 (freeware) - AfterDawn: Software downloads
You also might be experiencing some bottlenecking with your current setup which could result in reduced FPS.
Old October 6, 2011, 08:58 AM
Varroa's Avatar
Could be your PSU, what brand is it?
If you are still having issues you may have a bum card. The red lines are not normal at all. Try contacting support at MSI next.
AMD Radeon HD 6670 1GB & HD 6570 512MB Review Comment Thread SKYMTL Video Cards 4 May 5, 2011 02:13 PM
Possible PSU problem micul Power Supplies 3 April 4, 2011 08:11 AM
could this be a game problem or a video driver problem? Shadowmeph Troubleshooting 4 December 17, 2010 07:01 AM
Hardware problem or HAL problem? andynerd Troubleshooting 1 March 7, 2009 09:03 PM
