-   -   6950 clock speeds randomly dropping (http://www.hardwarecanucks.com/forum/video-cards/46945-6950-clock-speeds-randomly-dropping.html)
tianfeng October 2, 2011 05:46 PM
I am using an xfx 6950 1gb with a gelid icy vision cooler. Temps idle at 34 and load at 47. I have been noticing random drops in my performance while playing games. I just installed ccc 11.10 but i was getting this on 11.9 as well. if I open up kombuster the gpu goes to 900 /1400 clocks but I get drops to 500/1300 about every 5-10 seconds. It drops and shoots back up to where it was before. this is that my afterburner looks like
http://img853.imageshack.us/img853/1...ledgcjs.th.png
Uploaded with ImageShack.us
Is this normal?
Arinoth October 2, 2011 05:52 PM
Does this happen with every game or is it happening just in BF3 beta?
tianfeng October 2, 2011 05:54 PM
sorry, Trying to get the image to show up right. I am not even playing bf3 beta. I was just looking noticing it while playing any game.
Supergrover October 2, 2011 06:46 PM
Turn powertune to +20 in CCC. Fixed
Edit:
This will explain why.
http://www.hardwarecanucks.com/forum...-review-5.html
tianfeng October 3, 2011 03:15 AM
That was the first thing I did because I read that could be the problem. When I do that it sets my clocks back to stock but it is still doing the jumps.
Eluder October 3, 2011 06:18 AM
You sure this happens with games because I only have this problem with my high OC and furmark. Games don't seem to cause the TDP limit to kick in, even though I'm clocked at 975/1450.
If yours is happening on stock clocks I would say you have a weak PSU, or your video card may need an RMA.
tianfeng October 3, 2011 09:51 AM
My PSU is a tx850 so I don't think I am using more than that. I will try again after work and see if i am getting the same problem with gaming. I am hoping that it isn't an rma problem because I don't want to deal with xfx. I am not seeing any other major problems with it like artifacting. Is there a communication problem with afterburner and ccc? Should i use something else to overclock?
Eluder October 3, 2011 10:19 AM
Run it at stock and see if it happens, if it does, there's something wrong, if it doesn't, then your issue is your OC is too high for the TDP/Powertune limits.
I know there's an issue with unlocking the CCC limits via AB, but there's a registry hack out there that bypasses the CCC OC limits and then you can just use AB to overclock as needed.
tianfeng October 3, 2011 12:24 PM
I read about that this morning and I think I might give it a shot. I can also re-seat the gpu and see what happens. nothing ever just works. I am still dealing with the front two ram slots not working on an rma'ed crosshair v and i am waiting for bulldozer to see if it will fix it.
Supergrover October 3, 2011 12:31 PM
I had issues with getting my powertune settings to stick with AB installed, think it was Ari that asked if I had tried with AB uninstalled.
Uninstalled AB, rebooted, apply powertune in ccc, reboot, install AB, powertune setting stick.
Unfortunately AB doesnt like to change the corev's on my asus 6970's so for me now I use smartdr to adjust the clocks and voltage between ccc and AB.
