Old September 24, 2011, 05:53 PM
Beastylemon's Avatar
Default SLI GTX480 Different Brands?
Say I wanna SLI an ASUS ENGTX480 (w/ voltage tweak thingy) with a EVGA superclock+.
How would I get that to work =\
Is it possible to OC JUST the ASUS card?
P.S -I'm TOTALLY n00b with SLI, I'm an ATI guy =\
Corsair 650D / MSI Z77A-G45 / Intel i7-2600k / ASUS GTX780 / 4X4 Gig Corsair Vengeance DDR3-1600 / OCZ Vertex 4 120GB x2 / Corsair H100 / Corsair AX1200W PSU
Samsung U28D590D + ASUS VN248H x 3/ CM QuickfireTK MX Blues / Razer DeathAdder /SteelSeries 4HD
Old September 24, 2011, 05:57 PM
supaflyx3's Avatar
I'll work just fine, but the higher clocked card will downclock itself to the one that is a lower clock, and no you can't OC just one card.
Old September 24, 2011, 06:05 PM
Thank you VERY much, =)
Old October 4, 2011, 10:04 AM
AMC AMC is offline
Use MSI afterburner to overclock the core speed on each GPU. If not, then the one card will downclock for the same speeds.
Old October 4, 2011, 10:15 AM
Arinoth's Avatar
As long as they are 480s you are fine doesn't matter the brand at all.
Here I am: here I remain
Old October 6, 2011, 07:29 AM
I don't know about other overclock programs but MSI afterburner will not allow you to individually change your voltages. When you select the voltage tweaks, both cards will have their voltages synchronize.
Mixing RAM Brands/Specs okay? bkh2 RAM 9 January 5, 2011 06:19 PM
5850: Between Brands inTaiwan Video Cards 4 July 15, 2010 05:08 PM
Crossfire different brands? btecanada Video Cards 4 May 6, 2010 01:20 PM
Psu brands what to look for? upcoast604 Power Supplies 45 March 12, 2010 01:28 PM
Reputation of Gfx brands ? darth nissan Video Cards 16 December 22, 2009 07:02 PM
