Old September 22, 2011, 08:16 PM
Beastylemon's Avatar
Default AX850 or AX1200 for SLI GTX480 OC'd
2600k
2x GTX480
I have an AX850, but i dont OC
i keep both gpu's at stock, but im thinking about OCing everything.
would the AX850 be enough? if not, im thinking of buying the AX1200 (no other choice, if im going to upgrade, tis going to be that one)
Corsair 650D / MSI Z77A-G45 / Intel i7-2600k / ASUS GTX780 / 4X4 Gig Corsair Vengeance DDR3-1600 / OCZ Vertex 4 120GB x2 / Corsair H100 / Corsair AX1200W PSU
Samsung U28D590D + ASUS VN248H x 3/ CM QuickfireTK MX Blues / Razer DeathAdder /SteelSeries 4HD
Old September 22, 2011, 08:36 PM
Supergrover's Avatar
I run a 2600k @5g / 4x4 ddr3-1600 / 6 hdds / 6x140mm / 2x 6970 OCed to 950 core and a shit ton of usb crap and pull 670w from my kill a meter max.
Powered by a X-850
R.I.P.
Old September 23, 2011, 01:44 AM
GT7R's Avatar
I would have gone for the AX1200 just for the headroom and piece of mind (If budget isn't an issue), while with the 850 you will be close but should be fine.
Old September 23, 2011, 05:55 AM
Thanks guys :)
I MAY go with the HX1050 if I can find a used one =)
Old September 23, 2011, 12:44 PM
GT7R's Avatar
Won't be easy since it's a pretty new model, look for the HX1000, you should find them around 130-140$ :)
Old September 23, 2011, 01:04 PM
Why would they make 2 models 50w apart?
Old September 23, 2011, 01:21 PM
Soultribunal's Avatar
The HX1000 is an old ( but still good ) design back in the day. The HX1050 is the newer model that is available now, new platform , new OEM I believe (can't recall if the old one was a CWT or not).
That is why,
-ST
www.realhardwarereviews.com
[WTB] GTX 580 Beastylemon Buy/Sell & Trade 12 November 2, 2011 12:39 PM
[WTB] Corsair AX850 Munn Buy/Sell & Trade 1 August 10, 2011 06:57 PM
Low 12V rail on Corsair AX1200 Prolab Power Supplies 6 August 6, 2011 06:58 PM
[WTB] PSU Corsair Ax850 or AX 1200 Alpine Buy/Sell & Trade 12 February 6, 2011 12:19 PM
Corsair AX850 PSU + Silverstone FT02 case juice99 Troubleshooting 6 January 6, 2011 09:24 AM
