Old September 22, 2011, 03:30 AM
Default New graphics card
Hi guys
I am looking for a new graphics card although I don't want to spend much money on it and I don't want to upgrade other components. Well, maybe memory but that's it.
Currently I have a 8800GT. My motherboard is a Asus IPIBL-LB (I know it's not impressive but my PC is 5 years old)
Hit the link for full specs:
Motherboard Specifications, IPIBL-LB (Benicia) - HP Customer Care (United States - English)
I was thinking of going for a GeForce 300 series although I am not sure how to check if any of these cards are compatible with my motherboard.
Can anyone help?
Old September 22, 2011, 03:46 AM
GT7R's Avatar
What's your CPU and PSU?
Old September 22, 2011, 03:47 AM
Keltron 3030's Avatar
I hate to burst your bubble, but the nVidia 300 series was pretty exclusive to laptops and OEM's. It's also EOL'd
Whats the specs on your system? What resolution/games do you hope to play? where are you buying from and what is your budget?
FFFFFFFUUUUUUUUUUUU-
Old September 22, 2011, 04:17 AM
I have an Intel Core 2 Quad Q6600 2.4 GHz. PSU is 550 watt.
Budget is pretty low, I don't want to spend more than $150.
It's okay, I don't need a 300 series card, I can also settle for something lower or something that's better than the 8800GT.
Old September 22, 2011, 04:50 AM
GT7R's Avatar
If you're okay with buying second-hand, you can grab a good GTX460 1GB for 120-130$. If you're below 1080p, get the 768MB version for 20$ less.
Other options - HD5850, GTX285(but no DX11 then).
If you want only new, then look for a GTX560 non-TI, or a good non-reference 6850 (their reference versions run hot and loud).
Old September 22, 2011, 05:13 AM
I don't need 1080p, I don't think my monitor can support that in the first place.
Say I go for the GTX460, is it compatible with my mobo? How can I see that?
Old September 22, 2011, 05:19 AM
GT7R's Avatar
PCI-E x16, that's all you need, doesn't even have to be the 2.0 version.
Ah, and two 6-pin connectors from the PSU :)
Old September 22, 2011, 05:38 AM
OK excellent! Thanks! One more thing, will the 550 watt be enough or is it recommended to get some more power, say 650/700 watt?
Old September 22, 2011, 05:43 AM
Arinoth's Avatar
You should be fine with 550W for a power supply, though if its one of those generic ones that come with pre-built systems you would be better advised to upgrading that as well to a reliable brand such as corsair, seasonic or xfx
Here I am: here I remain
Old September 22, 2011, 06:39 AM
Soultribunal's Avatar
To Echo Arinoths words a check of what PSU it is (or even a picture would help) to ensure its a good one to power a better card.
-ST
www.realhardwarereviews.com
Intel HD Graphics with Graphics Card MoUnit CPU's and Motherboards 4 August 6, 2011 03:54 PM
Which graphics card should I get? deltatux Video Cards 12 July 20, 2011 06:33 PM
AMD Extends Graphics Performance Lead, Launches World's Fastest Graphics Card? Again! FiXT Press Releases & Tech News 2 March 8, 2011 03:32 PM
[WTB] Graphics Card: GTX 275/280/285 or ATI 5*** flightsimnerd Buy/Sell & Trade 7 May 10, 2010 09:39 AM
graphics card? Generic User #2 HTPC Systems & Software 4 July 25, 2009 07:50 PM
