Old September 5, 2011, 08:09 PM
yycraven's Avatar
Default GTX 560Ti 1GB or GTX 560Ti 2GB
So like title , I am wondering which would be a better card.
one is a GTX560Ti 2GB PCI-E Palit and the other is a evga GTX 560Ti 1GB
Would the Palit 2GB card perform better then the 1Gb
Was wondering what you guys think.
Thinking of replacing my Gigabyte GTX 470 OC card for one of these.
Thanks in advance.
ASRock Extreme 3,2500K,NH-D14,Patriot G2 16GB ,WD 750GB,640GB Sata ,2 GTX 470 SLi Thermaltake toughpower XT850W,Tech Station. V243H,2253LW LCD
heatware
Old September 5, 2011, 08:22 PM
SugarJ's Avatar
Depends on the resolution you game at. If you are on that 22" monitor in your specs, you're not likely to see any gains in performance at that resolution. The extra memory normally only helps at the highest end resolutions.
And to be honest, I don't think you'd see much of a difference between a 470 and a 560 Ti. Check the review here, your 470 should power through everything at 1680x1050. NVIDIA GeForce GTX 560 Ti Roundup: ASUS, EVGA, Gigabyte & MSI
Old September 5, 2011, 08:24 PM
yycraven's Avatar
well I am thinking of also buying a 27in LCD
NCIX.com - Buy Samsung T27A550 27IN LED LCD Monitor Black 1920X1080 5ms HDMI DVI VGA Component HDTV Tuner Speakers - Samsung - LT27A550ND/ZA - in Canada
So not worth the upgrade then, will check out that review thanks SugarJ
Ok I read review everything beats my GTX 470 except the GTX 460..lol
heatware
Old September 5, 2011, 08:31 PM
SugarJ's Avatar
Check that review, and it depends what you are playing on it. If you are noticing laggy FPS, then it might be worthwhile. But I can't tell the difference between 85 and 100 FPS, and neither can most casual gamers. I know my 470 was great except for Metro 2033. The only reason I upgraded was one of the reviewers needed to buy another 470 for SLI testing.
Old September 6, 2011, 10:43 AM
yycraven's Avatar
Yea maybe I will keep my GTX 470 for a while longer and see what comes out in the new yr.
heatware
Old September 6, 2011, 11:25 AM
470 is a good card (hot but a good card), I just got gtx 560 ti's and I do notice a bit of a difference but not a ton. Mind you I havn't oced or anything just all at stock.
You might be better to wait for a killer deal on a used card before buying a new one. Although your 470 is losing value fast I only had offers of like $150-$180 on mine.
Comp1 (Mine) : ASUS Sabertooth, i7 2700K, 8GB 2133 GSkill, XFX 7970 DD, OCZ Vertex3 240GB, OCZ Vertex3 480GB, 600GB VelociRaptor, Corsair 1000HX, Cool Master Cosmos 2
Comp2 (Wife's) : Intel DP67BG, i7 2600K, 8GB Corsair Vengeance 1866, 1TB HD, 2TB HD, Sapphire 7950 OC, Corsair 950W, HAF 922
Comp3 (Kids) : ASUS P8P67 Pro, i7 2700K, 8GB 1866 GSkill, Sapphire 7970, Crucial M4 120GB, OCZ Vertex3 240GB,1TB WD Black, Antec 850W, Antec 1200
Old September 6, 2011, 12:38 PM
yycraven's Avatar
Yea I will wait till the new GTX 600 series comes out in Nov or Dec with the 28nm Kepler core.
heatware
Old September 6, 2011, 01:15 PM
470 is going to be pretty close to the same performance as a 560ti. Wouldn't do it if I were you.
Desktop: X3 710, 4GB DDR2 1066, MSI Cyclone GTX 460, Seasonic S12II 500W
Away from home light Gamer: Acer Aspire 15.6", A8-3500m, 4GB 1333
Internet/General Use: Lenovo B570 15.6", i3 2330m, 4gb 1066mhz
GTX 470 vs GTX 560Ti trayton Video Cards 16 September 24, 2011 03:46 AM
Are my PSU good enough to run GTX 560ti? danthebrave Power Supplies 10 September 7, 2011 09:13 AM
560ti toasted? mo' power Troubleshooting 31 April 29, 2011 08:36 AM
[WTB] 560ti/570 Slaughter Buy/Sell & Trade 22 April 8, 2011 10:41 AM
560Ti SLI benchies... Delavan Video Cards 7 February 3, 2011 03:08 AM
