Old August 31, 2011, 07:07 PM
techman95's Avatar
Default BF: bc2 stutters!!!!!!
so heres my problem i just did a big up grade with a new cpu and mobo ( due to a different matter ) and so i thought my stutter problem would be gone, but no every time i play BF; bc2 multiplayer i get severe stutters and after about say 40 mins or so of playing my computer will lock up, and i have to do a hard reboot. i had the same exact problem before i did my upgrade. ive run every test under the sun prime, furmark, memtest, and a couple others. and ive kept my drivers up to date as well. the problem is only multiplayer on bf alone it affects no other games at all. and ive run out of ideas about what to do completely.
Old August 31, 2011, 07:09 PM
supaflyx3's Avatar
That sometimes happened to me, try this: Few things before playing BFBC 2 it helped a bit.
Old August 31, 2011, 11:08 PM
stupid question
do you have fraps installed by any chance ?
i had a friend with a similar problem, we found out his fraps was running all the time for some reason...video recording
Old September 1, 2011, 04:50 AM
Arinoth's Avatar
I've also heard certain older versions of MSI Afterburner aren't playing nicely with BC2 either, try running the game either with the latest beta version or without it running at all.
Here I am: here I remain
Old September 1, 2011, 12:52 PM
techman95's Avatar
wow i run fraps and i have an older after burner ill uninstall both when i get home
Old September 1, 2011, 02:53 PM
techman95's Avatar
so i uninstalled afterburner and fraps, and it now runs amazing. thanks for the help guys those two things would have been the last stuff i would have thought of
Old September 1, 2011, 07:39 PM
techman95's Avatar
another quick question, is there another program thats does the same stuff after burner does but isnt afterburner you know since that was my problem
Old September 1, 2011, 08:53 PM
well it was that or the fraps
don't know off hand. tired and not going to look it up ;)
Old September 1, 2011, 09:57 PM
Depends what you want to do with afterburner. Nvidia cards, you could use rivatuner for a lot of things.
Every 5 seconds, the CPU stutters for a split second Menello Troubleshooting 6 September 18, 2010 08:15 AM
my computer "stutters" bryab Troubleshooting 34 December 21, 2009 11:35 AM
