Old September 1, 2011, 11:18 AM
Probably a good move, but I'm curious. What was the price?
Desktop: X3 710, 4GB DDR2 1066, MSI Cyclone GTX 460, Seasonic S12II 500W
Away from home light Gamer: Acer Aspire 15.6", A8-3500m, 4GB 1333
Internet/General Use: Lenovo B570 15.6", i3 2330m, 4gb 1066mhz
Old September 3, 2011, 12:59 PM
no_pulse's Avatar
My system specs are:
Intel Quad Core Q6600 @2.40ghz
8gb of DDR ram
and well my new Geforce GTX 560ti
I paid $250 for the card I think. Good price, at least I think, especially when I was used to paying $500+ for cards.
They didn't have an EVGA, so I had top go with PNY. I hope they are a decent corp.
Originally Posted by kruzn4evr:
"The peppers fired a warning shot. Some were so loud and echoing that I was later told a few folks in
other aisles had ducked, fearing that someone was robbing the store and firing off a shotgun."
Old September 3, 2011, 01:28 PM
it should be fine
you should be happy with the card for awhile
Old September 3, 2011, 04:40 PM
8gb of DDR ram
You should be quite happy with the new card. You will very likely be CPU limited in many games now. You'll have to spring for an i5 2500k/MOB/RAM now to give the new card some breathing room.
Old September 4, 2011, 04:22 PM
Phill's Avatar
OC that Q66 and you will be fine. Heck an Oc'd Q66 (to 3.6 though) can handle two 460s at 900mhz.
Old September 4, 2011, 09:16 PM
bkh2's Avatar
Good move getting the 560ti over the 460. I did a comparison of my friend's gtx 460 with my gtx 275. Granted that the 460 outperformed my 275, it is not worth the money as an upgrade path (in my opinion).
Old September 4, 2011, 10:14 PM
yycraven's Avatar
I think going with the GTX 560ti was a good choice. Performs better then the GTX 460 and your old card.
ASRock Extreme 3,2500K,NH-D14,Patriot G2 16GB ,WD 750GB,640GB Sata ,2 GTX 470 SLi Thermaltake toughpower XT850W,Tech Station. V243H,2253LW LCD
heatware
Old September 5, 2011, 09:09 AM
Shadowmeph's Avatar
To be totally honest I wouldn't bother upgrading unless you need the dx11 and are an avid gamer, I was using a 260 for a while then it blew up and was replaced with a 1 gb 285, but the 285 created allot of heat so I was looking for a water block to cool it down and ended up buys a 2gb 285gtx with the water block on it and I have to tell you I can't see myself upgrading this card for a long time and I do a fair amount of gaming and I am totally satisfied gaming at this resolution.
but I have to admitt though I do feel like upgrading but it has nothing to do with needing to but it is just that dam addictive upgrading bug that is very contagious lo
  #19 (permalink)
Old September 6, 2011, 11:36 AM
The 560 ti's are nice I can attest to that got to finally do some gaming on mine this weekend!
You should be very happy with that choice :)
Comp1 (Mine) : ASUS Sabertooth, i7 2700K, 8GB 2133 GSkill, XFX 7970 DD, OCZ Vertex3 240GB, OCZ Vertex3 480GB, 600GB VelociRaptor, Corsair 1000HX, Cool Master Cosmos 2
Comp2 (Wife's) : Intel DP67BG, i7 2600K, 8GB Corsair Vengeance 1866, 1TB HD, 2TB HD, Sapphire 7950 OC, Corsair 950W, HAF 922
Comp3 (Kids) : ASUS P8P67 Pro, i7 2700K, 8GB 1866 GSkill, Sapphire 7970, Crucial M4 120GB, OCZ Vertex3 240GB,1TB WD Black, Antec 850W, Antec 1200
Is that a good choice for Case & Power for a Gigabyte X58A-UD3R ? Godis New Builds 14 July 18, 2010 07:08 PM
PhenomIIX4 955BE + 5850; ASUS M4A785TD-V Evo good choice? 15Down New Builds 8 December 27, 2009 02:36 PM
Is linux a good choice for an HTPC system? quikgp HTPC Systems & Software 6 April 28, 2009 06:17 PM
Trying to make a mobo choice... Rausch CPU's and Motherboards 10 February 6, 2008 06:05 PM
I have a choice to make... a video card? 3.0charlie Video Cards 23 October 24, 2007 03:55 PM
